Does this just pull off?
I am taking the cluster out. Does the knob for the headlights just pull off? I am pulling really hard and it is not budging...
1972 C10 1972 C20 ![]() |
computer illiterate
reach up in behind the dash on top of the switch is a spring loaded button push it down and pull out the knob
72 2wd blazer 72 swb 4x4 |
Wow, I can't believe how well you guys know these trucks...
How do I get the ignition out and the cigarette lighter? It's a '72 if it matters...
ignition switch removal
and Removing lighter Hope this helps you out bud. And yes, we all know these trucks in and out so don't ever be afraid to ask questions, thats how you get to know these things ![]()
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
After you pull that knob out, check & see if your lights are on.
It's just a cab, I am taking everything out for paint. I still can't figure out how this ignition switch is supposed to come out...maybe mine is just corroded or something. I can't get it to move.
I had a hard time with mine to. I ended up giving it a small squirt of WD-40 and it loosened right up. The actual key center part will come out separate from the ring bezel. Just keep at it, it will come out
