brake keeps blowing
ok today was the second time the front left brake cylinder on my truck has blown, why does it keep doing this, i have adjusted it and double and triple checked everything, so what can this be.
it is blowing only one boot off of the cylinder inside the drum and making a huge mess everywhere.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Broke and still trying
Is your drum worn overisized? I had that happen. THe drum was worn beyond it's limit and the brake would open all the way leading to the cylinder popping that little metal thing out! It sucked especially when you have to drop gear to slow it down!
Wiseass secured himself a BAN
Disk or drums?
Are the shoes in good shape? Is the drum worn out? Are the shoes adjusted right?... these are the three things that will cause a cylinder piston to "hyper-extend" and blow out the seal. Adjust (with good shoes) the star wheel untill the shoes just BARELY start to drag...they will tighten up to where they should be after you do a few stops in reverse.
