04-06-2004, 10:38 PM | #1 |
Can a 71-72 front end be installed in a 57?
Can anyone tell me if a front cross member from a 71/72 be easily installed in a 57 frame? I'm considering a project truck and would like to go the 5 lug/disc brake front end on it.
Any info is appreciated. Thanks. |
04-06-2004, 11:09 PM | #2 |
camaro sub frame would be the hot set-up...
thats what my buddy has on his 56.... and another has on his 36.... jmo |
04-06-2004, 11:39 PM | #3 |
i thought you were talking about the front clip!!! lol. i plan on going with the camaro sub on my '46 plymouth. if it works out alright i might consider doing my dad's '65 suburban. i've heard that it's actually pretty simple. some assembly required.lol.
04-07-2004, 12:04 AM | #4 |
The reason I want to go with a truck cross member is because I would have one readily available - either one from a 72 or one from an 88 1/2 ton.
Does anyone know if this is practical, difficult, whatever? Thanks. |
04-07-2004, 02:00 AM | #5 |
i dont know how difficult it is but my neighbor bought my old 72 parts truck to do that with, he wanted disc brakes and a posi for his 56 truck, he just took both frames to a shop and said i want this done, looks good now he has to wait on the body to get done
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
04-07-2004, 02:24 AM | #6 |
I'm sure it could be done but would possibly need to be narrowed. I had a 52 with a nova or camaro sub and it was a perfect match up with the existing frame rails.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach (upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL) 71 Custom Deluxe 350/350 Tilt/PS/PB 00 Blazer |
04-07-2004, 03:34 AM | #7 |
With a plasma cutter and welder, it can be done. The Camaro/Chevelle clip would be a little eaiser though, not by much, but a little.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
04-07-2004, 03:39 AM | #8 |
i put a mustang 2 front end under my old 57 chevy p/u. easier than the camaro clip cuz you don`t have to cut the frame. you can get parts off of a mid 70`s mustang at a junkyard cheap and get rack and pinion steering. someone makes a rotor that fits the m2 spindle with a 5x5 lug pattern.
Anthony |
04-07-2004, 12:47 PM | #9 |
Living In The Past
the camaro or mustang 2 clips are ok if you want your truck low, but what about if you want it to sit about stock hieght?
04-07-2004, 12:58 PM | #10 |
It's a catastrophic success.
theres a topic in the 47-55 board on using a 77' I allways thought they were to wide but, might use the same principles for a 57
http://67-72chevytrucks.com/vboard/s...threadid=98509 |
04-07-2004, 04:04 PM | #11 | |
