04-07-2004, 11:55 AM | #1 |
need body mount help
I'm in the proccess of swapping the rusted shell off my 86 k10 with a much better 87 c10 donor. The body mounts came off the 86 pretty easy exept the cab. I tried an impact on the rear cab mounts and they wouldn't budge....ended up torching the hell out of them to cut them out.
My question is: If the ones on the donor are like this what is a good tip for getting them apart without cutting it apart? |
04-07-2004, 01:11 PM | #2 |
yeller
Do you mean the body mount bolts?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-07-2004, 01:16 PM | #3 |
yeah, but to torch the bolts I ended up burning the rubber mount and cutting into the cab support.
04-07-2004, 01:21 PM | #4 |
yeller
How about cutting off the bolt head, removing the cab, and taking the rest off when you have better access to them?
I have found that wd-40/liquid wrench, a propane torch, and a big breaker bar will loosen just about every stuck bolt. Working the bolt back and forth will help loosen it as well.
04-07-2004, 01:23 PM | #5 |
mmmm....Rye and Coke
A strong breaker bar, another bar to extend it so you have alot of leverage, and snap the bolts
04-07-2004, 01:59 PM | #6 |
I'll try that, I already broke an extension because I couldn't get the breaker bar in there without it. But that was all 3/8" stuff. I'll go bigger next try!
