Old 04-07-2004, 03:02 PM   #1
ocbaud
Garage Queen Material
carb tuning???
okay, i bought a vacuum gauge today and am gonna borrow a tach that works from a friend of mine. my dad is getting a timing light today and tommorow we are gonna get the thing running right.
so, after the timing is set correct this is what i need to do?:
1. turn the idle mixture screws 1.5 - 2 turns out from completely in
2. set the idle speed(which screw do i set it with? the one by the choke, or the one by the throttle bracket?)
3. continue turning the IM screws out about a 1/4 turn each time, while bringing the idle back down after they are turned.
4. continue doing that until the vacuum will not rise anymore on the gauge. so that it has the highest vacuum at the desired idle rpm
does that sound right?
ocbaud is offline   Reply With Quote
Old 04-07-2004, 03:20 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
#2, it is the one by the throttle.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-07-2004, 03:35 PM   #3
ocbaud
whats the difference between the 2 different screws?
Old 04-07-2004, 04:01 PM   #4
Russell
Professional Grade
Russell's Avatar
One is for the cold idle speed, and the other for the hot idle speed.
When the truck is cold, it is suppost to run faster than when it is hot to keep it from dying.
The one by the throttle bracket is the one that you will be wanting to adjust
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-07-2004, 04:42 PM   #5
ocbaud
do i need to have it warmed up before i adjust it?
Old 04-07-2004, 04:49 PM   #6
Captkaos
Captkaos's Avatar
If you are having alot of problems with it, by the time you get started on adjusting it it will be warmed up by then.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-07-2004, 04:55 PM   #7
ocbaud
so pretty much it does
Old 04-07-2004, 06:55 PM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Should have gotten a Edelbrock Much easier to tune.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-07-2004, 10:21 PM   #9
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
To each their own. Yes, warm it up and continue. Be sure you get your ignition problems straightened out before you start tweaking the carb. Jet produces an excellent product. If you got the recommended carb for your engine it should not require much else other than setting the idle speed and mix.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-08-2004, 12:22 AM   #10
ocbaud
my cam is a little above what they recommend for there stage2 carb, which is what i have.
but i believe all i need to do is set the idle and mixture
Old 04-08-2004, 03:47 AM   #11
67_SS396
You have the right idea and yes, the engine needs to be up to operating temp before you start making adjustments to the air/fuel mixture.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 04-08-2004, 04:07 PM   #12
ocbaud
i got the timing set to 12 degrees, but now i need to tune the carb to run well. it keeps wanting to die on me in idle
also, i cant get my friends autometer sportscomp tach to work
Old 04-08-2004, 04:10 PM   #13
NeCrOmAnCeR
Where did you end up hooking the vac advance?
And what kind of vacumme is the engine making?
Old 04-08-2004, 04:11 PM   #14
ocbaud
right now its on ported, but i've tried both and it doesnst seem to matter which one its on. it does idle a lot higher with it disconnected though.
Old 04-08-2004, 04:15 PM   #15
NeCrOmAnCeR
It idles higher with it disconnected from the ported source?
Old 04-08-2004, 04:16 PM   #16
ocbaud
yes
Old 04-08-2004, 04:22 PM   #17
NeCrOmAnCeR
If you put your finger on the ported source can you feel it pulling on you? In that elplanation I gave on you're post asking where to put the vac advance line, you can hook it to the EGR port for a ported source. the one labeled for dizzy is a full port.
Old 04-08-2004, 04:27 PM   #18
ocbaud
i've hooked it up to both ports. and it seems to idle higher with it disconnected.
Old 04-08-2004, 07:21 PM   #19
NeCrOmAnCeR
Try hooking the vac advance up to the EGR port. It is the one in the above pic just below and to the right of the "PCV label box" The one to the left of the PCV port. This is also a ported source. At idle on a ported source, the vac advance should see no vac at all. So disconnecting the line should not have any effect on the idle speed. Also, just a reminder, when you set the timing to remove the vac advance line and plug the carb port. Connect it all back up when finished.
Old 04-08-2004, 08:11 PM   #20
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Why don't you lock out the advance and not hook it up. You don't need it with that converter anyway.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 04-08-2004, 08:14 PM   #21
milner
milner's Avatar
Sounds like your idle circut needs to be opened up. I had a Comp cam w/230 dur. at .050" and it would not idle. I can't remember the size to drill the circut with but with the cam you have it sounds like it needs to be.
milner is offline   Reply With Quote
Old 04-08-2004, 08:31 PM   #22
ocbaud
well the carb should run because its already been worked on. its a stage2 qjet by jet performance. although, the recommended specs on the box it came in were a little smaller cam then what i had.
it says this:
" This carburator is intended for Chevy Truck engines with mild performance upgrades such as:
DUAL PLANE ALUM. INTAKE MANIFOLD
HEADERS
COMPRESSION RATIO OF 8.5:1 - 9.5:1
MILD PORTING ON CYLINDER HEADS OR pERFORMANCE HEADS
CAMSHAFT SPECS:
duration @ .050 MIN. 210 DEGREES
MAX 222 DEGREES
LOBE SEPARATION ANGLE 110-114 DEGREES
Old 04-08-2004, 09:16 PM   #23
bpmcgee
bpmcgee's Avatar
Did you set your initial timing with the vacuum advance connected? That's a no-no.
Brian
bpmcgee is offline   Reply With Quote
Old 04-09-2004, 09:51 AM   #24
ocbaud
no, it read 12degrees with it disconnected. and read about 22 or so with it connected.
we got it running and idleing good. i'm leaving in a bout an hour to go to the exhaust shop to put pipes on it. its just really slow. the 305 was faster
i dont know if thats from it only having 4 miles on it, or from the cam, or from the 2500 stall, of from my 2.70 gears, or all of them
Old 04-09-2004, 08:42 PM   #25
NeCrOmAnCeR
The stall converter will help your acceleration with that cam. It lets the engine rev more to put it into its power band. Those gears though, they have got to go. Is it finally ideling like it should? When in park does ir respond nice and quick?
