Old 04-07-2004, 08:09 PM   #1
TIMSPEED
TIMSPEED's Avatar
Why are my rear brakes so "grabby" and locking up?
Lately, when I'm coming to stop, my rear brakes will GRAB and lock the back tires and I'll start skidding. I know these are supposed to be self-adjusting, and I've tried backing up and hitting the brakes to get them to adjust. But it keeps randomly doing it. What should I be looking at to fix or lube? The starwheel?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-07-2004, 08:30 PM   #2
low 84
low 84's Avatar
take the drums off and adjust them yourself
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-07-2004, 08:34 PM   #3
TIMSPEED
TIMSPEED's Avatar
Did I mention I hate drum brakes? I don't have to take them apart do I? Just like move the starwheel or what?
See Them Here
Old 04-07-2004, 09:05 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
wheel cylinder or axle seal
You either have a rear brake cylinder leaking and putting brake fluid on the shoes, or worse yet, an axle seal leaking gear lube on the shoes. Brake shoes don't like liquid. Check both sides. My advise is to replace them in pairs. Might as well put brake shoes on and clean or turn the drums while your at it. Pull the drums and take a look.
Old 04-07-2004, 09:34 PM   #5
TwinTurbo
TwinTurbo's Avatar
I have the same issue on one side, will take the thing apart this weekend.. let's hope it's the cylinder seal and not the axle...
TwinTurbo is offline   Reply With Quote
Old 04-07-2004, 09:55 PM   #6
low 84
low 84's Avatar
with the rear jacked uptry and spin the wheel, there should be slight tension, but not much. if there is too much just take the drum off and back the adjuster off a tad (use a scre dirver or break spoon if you have one and turn the little toothed wheel)and try it out.
'05 1500 Crew Cab
RIP
Old 04-07-2004, 10:08 PM   #7
KShortell
KShortell's Avatar
TIM--
Like others have mentioned, see if it's on both sides or just one side.
I had the same thing happening after my truck was repaired from being side-impacted in 1994. The rear axle seal on one side was leaking from where the left axle was replaced. The drum was being lubed, causing the other side to lock up due to imbalanced braking force.
Leaking brake fluid could have the same effect.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 04-07-2004, 10:08 PM   #8
bigblock73
yeller
bigblock73's Avatar
I agree with lolife99, I had a similar problem and found it was a rear seal leaking and soaking my shoes.
bigblock73 is offline   Reply With Quote
Old 04-07-2004, 10:14 PM   #9
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Is this occuring during normal stops, or during a panic stop? If it happens during normal stops the answer has already been mentioned, but if it happens during a hard stop the proportioning valve is going south.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-08-2004, 11:22 AM   #10
Gibble
mmmm....Rye and Coke
Gibble's Avatar
Re: wheel cylinder or axle seal
I had the same problem.
Replaced the axle seals and brake cylinders (both were leaking :eek) and it's perfect now.
Gibble is offline   Reply With Quote
Old 04-08-2004, 12:37 PM   #11
Zilverado
Zilverado's Avatar
Another vote here for leaky axle seals or wheel cylinders - quite common in my experience.
Simple fix in either case. Axle seals take a little more time (OK, quite a bit more ), but still fairly simple. One good thing about axle seals - they are cheaper to replace than the cylinders, assuming you supply the labour.
Zilverado is offline   Reply With Quote
Old 04-08-2004, 12:43 PM   #12
Prerunner1982
Prerunner1982's Avatar
i have this happen but very rarely, usually during cold mornings when pavement is wet. i think i just need to adjust or bleed the brakes.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
