Need help on future Ring & Pinion swapout
Here's my problem. I am ready to install my axles and was going to replace both tie-rods on the steering rod (one on each side). As soon as I get the truck on the road I will replace the 3.07 gears with 3.73's. My question is do I have to remove the steering rod that runs in front of the diff cover to replace gears and/or carrier. The answer to this will determine if I will put on the new tie-rod's or save them for when I do the gear job.
Thanks ya'll |
5-7 dropped 87 CC Dually
If its in front of the cover. yes.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
Thats what I was figuring. Never had messed with the pinion gears, so I don't know what you can work around.
Thanks |
