Old 04-08-2004, 01:26 AM   #1
robby
Semper Fidelis
robby's Avatar
can you drill out your rear?
can you have the axels of a 6 lug rear end for 5 lug? If so is it a big deal or can any machine shop do it? The reason I ask is that my next possible truck is a 69 CST big block with air, t400 tranny and a posi rear end. I already have the 5 lug rims and front spindles from a 72.
thanks
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 04-08-2004, 01:47 AM   #2
SS55
I have had a couple of sets of 6-lug axles redrilled for 5-lug. Any competent machine shop should be able to handle it.
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 04-10-2004, 12:58 AM   #3
robby
Semper Fidelis
robby's Avatar
Thanks, how much did you pay for that? I had a 12 bolt rear end out of a 66 chevelle once that had two bolt patterns on it.
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 04-10-2004, 02:53 AM   #4
SS55
It's been a few years, but it was $75.00 for a pair back then.
55 GMC
55 Belair 2dr HT
67 El Camino
Old 04-10-2004, 09:22 AM   #5
mooneyes
mooneyes's Avatar
me and 6772king just redrilled my 5 bolts to a 5 on 4 3/4 pattern...we put a car wheel up in a lathe and hogged the center hole out so it fit tight on my axel then just transfer punched it and drilled...
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 04-10-2004, 01:59 PM   #6
robby
Semper Fidelis
robby's Avatar
was it hard to get through the flange?
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 04-10-2004, 07:41 PM   #7
mooneyes
mooneyes's Avatar
...not at all..even drilled it by hand..pilot hole first of course
78 caprice project
Old 04-10-2004, 09:20 PM   #8
fast71
Drive it like U stole it
fast71's Avatar
heck just go the the junk yard and get aset out of a 76 down twelve bolt . we put a set in a friends 70 with no problems.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 04-10-2004, 09:49 PM   #9
1971 Cheyenne
1971 Cheyenne's Avatar
That worked because your friend's truck was a later model '70, they started making wider rears in the middle o fthe '70 model year. 71 up axles WILL NOT work in a 69 rear end, they are abotu 3/4 inches longer if I remember correctly.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 04-10-2004, 09:56 PM   #10
robby
Semper Fidelis
robby's Avatar
The one in question is a 69
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
