04-08-2004, 01:37 PM | #1 |
yeller
two transmissions in one vehicle?
I have heard of Advanced Adaptors OD/UD units, but NEVER heard of installing two transmissions together!
Here is the truck. A column shift AND a floor shift? Sounds confusing.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-08-2004, 01:55 PM | #2 |
Live from Atlanta
Hey, with 3 reverse gears...I could put one of those in my truck and go race the "ricers" in reverse at the local drag strip.
I'll tell them it's a new front wheel drive experimental...
Paul |
04-08-2004, 04:14 PM | #3 |
I'd like to see how they provide hydraulic pressure to the second tranny.
04-08-2004, 04:37 PM | #4 |
Project92 SWB stepside
WTF why would you need 3 reverse gears??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
04-08-2004, 05:25 PM | #5 | |
1987 Chevrolet Silverado 2005 Chevrolet Silverado |
04-08-2004, 05:32 PM | #6 | |
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
04-08-2004, 08:07 PM | #7 |
MJ at CK5 is rumored to be working on putting dual SM465s in his truck.
04-08-2004, 08:37 PM | #8 |
i can see the advantage of two trannies in a rockcrawler...but not in a street truck. especially two TH400's...i could maybe see a th400 mated to an overdrive trans of some sort...
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
04-08-2004, 10:02 PM | #9 |
I remember reading about that in a Car mag back in the late 80's or 90's.
04-12-2004, 01:39 PM | #10 | |
I guess I can see the reasoning for a 2wd tow rig. It would be like a one up on a gear splitter. Seems wasted on a 2wd for drag racing.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
04-12-2004, 03:29 PM | #11 |
i can understand 2 tcases, but 2 trans... dont guess i ever thought about it.
04-12-2004, 07:51 PM | #12 |
RHCP afficianado
would that be good for highway travel or is that mostly good for offroading? If its cheaper than a gearvenders setup then maybe I can look into doing something like that then I might not have to sell my truck.
~Ryan~ 89 S-10 Blazer with a 4.3L 96 Ford Crown Vic P71 4.6L V8. This car rocks. Here are some links to some good music. Jack Johnson Donavon Frankenreiter |
04-13-2004, 04:31 AM | #13 |
I went goose hunting in S. La. years ago & the guy who owned the place had a marsh buggy made from an old shorty school bus with the top cut off at window level, tractor tires set up duallie-style, & 2 3-speed trannys in tandem.
04-13-2004, 12:27 PM | #14 |
Ultimate Diesel Dude
I've seen lots of tandem manual transmission setups and tandem automatic/manual setups, but never tandem automatics! How weird! According to the literature, the second tranny doesn't have a pump. I can see some tubing hooking the two together, so I would bet that the first tranny supplies hydraulic pressure to the rear one. Strange. The pamphlets look old. I wonder if it never caught on.
A friend of mine has an old 65 Ford F-100 with two manual trannys. It makes a great crawler out in the hayfield. A lot of the older over the road trucks had two transmissions, with two gearshifts sticking out of the floor. The front transmission was a regular 5 or 6 speed forward gears and reverse, while the second tranny was just a 3 speed underdrive, direct drive, and overdrive. In fact, my dad has a custom built truck with an Allison auto followed with one of those 3 speed manuals. Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
