Old 04-08-2004, 02:50 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
mirror bolt hole fix
the bolt on my tripod mirror is a bit big. the bold wont tighten. cant use a bigger bold because you are limited by the size of the hole in the support.
is there any thing out there that i can put in the hole? ie, a threaded insert? perhaps there is a specail deal i can have put on a t a body shop// any one know?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 04-08-2004, 03:13 PM   #2
Psychohamster
Either helicoil it or use a large dab of red locktite
Psychohamster is offline   Reply With Quote
Old 04-08-2004, 03:29 PM   #3
mtdave2
mtdave2's Avatar
the door metal is to thin for that.
69 k10 Suburban
Old 04-08-2004, 03:32 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
Remove the door panel and use a bolt and nut.....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-08-2004, 03:37 PM   #5
cwilli84
1FINE69
cwilli84's Avatar
What about a clipnut or speednut type of clip that slides over the edge of the hole maybe weld it in place.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 04-08-2004, 06:36 PM   #6
Olden Days
Living In The Past
Olden Days's Avatar
ever heard of "rivnut" ? the tool is much like a rivet gun but it has a trheaded stud that you screw a rivnut onto then install like a rivet by putting in the hole and smashing down. Then unscrew the threaded stud out of there and there you go. I am not clear on the area you are talking about so this will not work if you cant drill the lole out bigger to accept the larger outside diameter of the rivnut. If you are talking about the mirrors that hang on your doors then I think it would work.
Olden Days is offline   Reply With Quote
Old 04-08-2004, 08:52 PM   #7
Jeepster376
Jeepster376's Avatar
Definately, "Nutserts", or "RivNuts", two different brands of rivet style thread inserts for just that purpose.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-08-2004, 08:57 PM   #8
Jeepster376
Nutserts are easy to install with the inexpensive instalation tool, or even an ordinary wrench and allen wrench, Rivnuts I think the tool is much more expensive.
Old 04-09-2004, 05:13 AM   #9
OhioDan
OhioDan's Avatar
I bought a "NUTSERT" tool off of a Mac Tool dealer years ago, just for this sort of thing. As stated above, it looks like a round barrel with threads inside. Drill out the old nut( you should be able to see what size pretty easy), and install another with this tool. It operates almost just like a rivet gun. I'm sure there's others out there, just don't know them by name.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-09-2004, 07:59 AM   #10
Blue Beard
Blue Beard's Avatar
Are these aftermarket mirrors you are dealing with....?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-09-2004, 08:45 AM   #11
tom hand
CCRider
tom hand's Avatar
A "RivNut" would be best but if you are on a budget....I bought a truck that someone had used plastic license plate inserts. They worked great
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-10-2004, 12:06 AM   #12
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
If you're on a budget I would take a file and make the hole in the mirror support a wee bigger to fit the wee bit biggger bolt. Just my cheap way of thinking
WRMZ71 is offline   Reply With Quote
Old 04-10-2004, 07:30 PM   #13
mtdave2
mtdave2's Avatar
ill look into those things.. thanks..
this is a stock tripod mirror,
i am trying to fix this right.....
the bolt idea is my last resort, the down side to it, is if you want to take the mirror off. you have to take the door pannel off too.
69 k10 Suburban
Old 04-10-2004, 11:22 PM   #14
86SILVERADO
86SILVERADO's Avatar
I just used the liscence plate deals on mine. You just have to shave off the corners a bit with a razor knife to get them to fit in the hole in the door.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
