Insert funny comment.
![]() Join Date: Dec 1999
How are these rust problems typically fixed?
Are there replacement panels or is it all custom sheetmetal work? Curious how these 2 problems are normally fixed.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
and 2
Wiseass secured himself a BAN
Cut out the bad, make patch panel, weld in.
user # 2756
![]() Join Date: Jun 2001
There's panels for the second pic. Will be doing it on mine soon.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Like Jim said, there is a panel for the second one. The first one should not be hard to make a panel for. Cut out all the rust and then make a larger panel a little bigger than what you cut of the cab. (Trim to fit). Pound it to shape roughly and then tack weld it into place starting on one side and weld up to the curve on the cab. you will probably want someones help to push on the panel as you weld or you can try to do it yourself. Just take your time and make sure the panel is in the right spot before you tack weld it. Good luck
Low68
Build Thread |
Thanks everyone. Didnt realize there was a panel for 2nd piece. Looking forward to doing this. Just now learning to weld. Been wanting to learn for many years.
Is it called the "inner lower cowl". Just browising some parts magazines looking for the right sheetmetal part. Last edited by lock; 04-08-2004 at 10:54 PM. |
Stepsides Are Bedder
I just did mine this past weekend. It looked worse than picture number two before I started. I took my air cutoff tool and cut the rusted metal away so I had a straight line of good metal to weld to. I made a template out of heavyweight paper (I used a hanging folder) and, using the cutoff tool again, cut a patch out of a piece of sheetmetal that was similar in thickness. I ground the patch until it was a good fit, and then butt-welded it in place. I like to have a little gap along my weld seam so that when I grind the bead down I still have plenty of penetration. If it were in a more visible area I would have skim-coated it with some filler and sanded it smooth, but I didn't bother...I just painted it and used some silicone to seal it to the floor pan. You can't hardly tell it's been patched.
There was no seam sealer applied at the factory on the passenger side on the seam that is under the water drain at the corner of picture #1, and the water wicked into the corner of the cab where it collected in that low spot the Chevy engineers wisely thought to include in our trucks over the last 35 years. When you get done patching, be sure to clean out your cowl drain area and run some water into that area to make sure you find the source of the water leak into the cab. |
Panels
I believe there's a cowl panel available also, if not find a donor firewall.
Have fun ![]() |
Get a LMC catalog, very food exploded views of what's available...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
now thats a true COON DOG
![]() Join Date: Nov 2000
Wow, I didn't realize that they made a cowl patch panel......
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
#11 | ||
I recieved the new LMC in the mail a few days ago and I looked @ the patch panels they offer, but I could not find a replacment patch panel for #2. If you have the new LMC cat panels are on page 20. if it is there then correct me plz.
RIch
