Old 04-08-2004, 10:09 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Aluminium Trim
What is on the outside of the aluminium trim and how do you get it off? I have heard that Easy-Off oven cleaner will do the trick. I sanded through it with alot of work and 220 grit. I then buffed it with a buffing wheel and the sanded spots look like chrome...the other stuff, where it did not sand through to the aluminium, still looks like s&!t.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-08-2004, 10:15 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Anodizing
When automotive manufacturers switched from chrome-plated steel to aluminum, they did so with the knowledge that the anodizing of the aluminum would insure the appearance for years to come. Without the anodizing, the aluminum would quickly lose it's luster and would react to the pollutants in an automotive environment. Now that these truck parts are at least 32 years old, it is apparent that anodizing doesn't last forever.
You found a way to get past the anodizing, but you also found that it isn't easy. There are people who know how to re-anodize them, but I don't know if it wouldn't be cheaper to just buy replacement trim parts....or just remove it altogether, like I plan.
Why not plug "anodizing" in to a search engine and see what pops up?
Member Nr. 2770
Old 04-08-2004, 10:26 PM   #3
McGillicutty
I had the same problem with my grille. It was a lot of work shine it and it doesn't stay nice for long. New grilles are so expensive. I've been trying to find someone locally that does anodizing , no luck yet.
McGillicutty is offline   Reply With Quote
Old 04-08-2004, 10:36 PM   #4
Jeepster376
Jeepster376's Avatar
You can buff it out real nice with the anodizing stripped off, but it wont last long at all without regular polishing. Anodizing protected it for 30 years. Probably lasts better than chrome. An anodizing house, can strip off the old and re-anodize it, but it's probably more expensive than new trim.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-08-2004, 10:42 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I have some grill loops(67)I plan on polishing and clear coating to preserve the shine. Do you for see a problem with that idea?
sneakysnake is offline   Reply With Quote
Old 04-09-2004, 12:32 PM   #6
69 Short Fleet
Jeepster376 is correct! Once you get it down to the raw aluminum and get it polished all you need to do is maintain it with autosol or any good quaility aluminum polish periodically. I personally would NEVER clearcoat polished aluminum, I have not seen a clearcoat yet that did'nt "yellow" over time (or turn a milky yellow). Once it yellows your back to square one and have to remove it and start over.
69 Short Fleet is offline   Reply With Quote
Old 04-09-2004, 04:00 PM   #7
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
you might be able to use this.... diamond clear from www.eastwoodco.com this stuff is good for all kinds of metal & it will not yellow.........shine up your stuff spray it with this & your good......
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
