04-09-2004, 04:27 AM | #1 |
driving is in my blood
c-notches suck to install
I decided after more then a year with the flip kit that I wanted to put my c-notches on. Couldn't be too hard, and besides, Mike did it with a sawzall so I hopfully could too.
Big mistake. Mike, I gota give it to you. Your skills with the sawzall cannot be compared. Hell, if it wasen't for my friend Jason helping I wouldn't have gotten even half way on sawing that frame off. As it sits, its an ugly cut on both sides, and they are just a tad too far foward. Not enough to affect anything [I think ] but if you check you can tell. Anyways a warning to everyone: do not attempt this install with only a sawzall and a single 1/2" drill bit and WD40. It works, but it ain't pretty
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
04-09-2004, 12:50 PM | #2 |
i used a Matco Red Line Anti Vibration air saw to cut my frame to put the 81+ bumper on it. part no RL 1325 if i remember correctly. cut through it like a hot knife through butter. yet another case where you get what you pay for.
04-09-2004, 02:43 PM | #3 |
BAD BOW-Silverado XST
Yup, one reason I bought an air compressor.
04-09-2004, 03:51 PM | #4 | |
04-09-2004, 06:00 PM | #5 |
Anyone ever used an air body saw to cut a frame?
I know most are only for 16-18 gauge at the max., but I am sure it would work. Has to be easier to handle then a sawsall. Plasma is the way to go. Too bad they cost so damn much.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
04-09-2004, 09:20 PM | #6 |
angle grinder with 4 inch cut off wheel.
i've done 2 truck like this and the cuts come out near perfect. i'm pretty good with a grinder though
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-09-2004, 09:38 PM | #7 |
Under construction!
I used a Craftsman cut-off tool w/ great results on my 86' C10.
2001 Silverado bagged on 22's. *Sold* |
04-09-2004, 11:25 PM | #8 |
It followed me home?
You guys need to come to colorado and help me with mine. I'll buy the beer
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
04-10-2004, 03:39 PM | #9 |
ha.. I used an angle grinder also and it was a pain in the butt. The hardest part to me was drilling all the dang holes. I went through 2 brand new drills.
84 Chevy Stepside, 350, TH350, 268h Comp cam, Hooker headers, MSD Pro Billet, Edelbrock Performer manifold and 1604 carb, 40 Series Flowmasters dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi |
04-10-2004, 04:02 PM | #10 |
paper or plastic?
I have a flip kit on my 77' and I just put 2 inch shackles on it . I had to c-notch the frame. I used a grinder with a cut off wheel on it, what a pain in the ass. Then I welded 1/4" steel to the frame for the notch. Then I put my bed back on and the damn rearend hits the bed floor when I jump on it so I had to notch the bed floor also..... lots of work for 2 more inches but well worth it. The rear looks so much better now and its still not that low cause' my rear tires are 31" tall
04-10-2004, 04:22 PM | #11 | |
04-10-2004, 06:14 PM | #12 | |
04-10-2004, 06:34 PM | #13 |
I like metabo grinders with 5 inch cutting disc . these work great for cutting. metabo grinders are one of the best electric grinders on the market. For fine cutting air powered 90* angle peanut grinder with thin cutting discs work great. cutting torch ( oxyacetylene)work great also. Even for burning the holes for the bolts. a torch works just as good as a plasma cutter. I leave the plasma cutter for stainless steel. I cut my c-notch with a oxyacetylene torch. Buned the bolt holes with a torch.
04-10-2004, 09:38 PM | #14 | |
I just bought a cheap air saw a few months back and havent used it much, but it seems like it would zip through a frame no problem. ---------- I use my 4" grinder for cutting everything. If you use the cut off wheels you can get a cleaner cut then the grinder wheels. The flap discs work great for cleaing edges and blending in welds. ---------- When drilling through steel, a good bit and cutting oil is the key. The right bit and some cutting oil make it much easier, faster, and a cleaner hole. The cutting oil keeps the bit cool and makes it last much longer. You can buy a little bottle of the cutting fluid at Lowes/HomeDepot and just dip the drill bit in the bottle before you drill each hole.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 04-10-2004 at 09:42 PM. |
04-10-2004, 09:39 PM | #15 | |
04-11-2004, 02:18 AM | #16 |
You get what you pay for
I'm not sure what was so hard about using a sawzall. Worked like a charm for me. I tried a 4" side grinder with cutting wheels but liked the sawzall better.
Mike 1985 Chevy C-10 |
04-11-2004, 05:31 PM | #17 | |
STILL PLAYS WITH TRUX
When drilling steel you want to drill at a very low RPM setting if you do this your bit will last a very long time. |
