gasket between NP205 transfercase and adapter
Is there a special gasket that goes between the adapter and transfer case on a np205? I just got done swaping out the 10 spline input, for the 27 spline input, but the new adapter doesn't fit tight aginst the t-case. It looks like the input shaft bearing is holding it back.
Broke
Yes there is a gasket that goes between the adapter, and the NP205.
72CheyenneSuper1ton4x4BigBlock |
![]() Join Date: Feb 2000
You swapped out a manual for an auto? The adapters are different for those transmission/transfer cases. The manual one is longer than the auto. As for the gasket, I just used RTV silicone on top of what was left there, hasn't leaked a drop.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
I changed the adapter also. There is a small gap between the adapter and the t-case after I tighten the bolts up.
