i bought this tranny from my buddies uncle he said it was a TH400 but it doesnt measure right its an inch longer then a TH400 and stuff heres the numbers on the Vin Tag
B 73C 383 C 73-BC 149556 can someone help me find out wether it is a TH400 or TH375????? Thanx |
TH400
This is from memory and therefore I maybe wrong but the rule of thumb I use is
6 bolts on the tailhousing = th400 4 bolts on the tailhousing = th350 top of bellhousing where it mounts to the block has a valley its a from an olds/buick/pontiac...... top of bellhousing is peaked its a chevy. hope this helps swdobbs..... |
here.....check the pan shape.. it may be a th400 with a longer tailshaft tooo. not really sure. are pics a possibility???
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
its all about the +6 inches
TH350 has a kick down cable, TH400 does not.
There were more than one length on the trannys, so if your compairing it to just one measurement, then that won't rule out anything. |
I dont normally do anything but read here but I thought I could help. I noticed that you ask about a 375 turbo, well that trans was a cadillac trans. Same style bellhousing with a 400 front housing,modulator on the side behind the bellhousing.this trans has a longer tail shaft than a normal 400 and the output shaft is not the same as a 400 it uses a 350 yoke because of its shaft size. I hope this will help you to identify your unit.
John |
I didn't even catch that.
If it has the chevy bolt pattern, then it is not a caddy tranny, they used the BOP pattern. |
Use the pan chart that Orange posted
If the numbers you posted are on a 400 they match up to a 1973 to 1974 BOP model that was use on all other than 455 V-8 Century & Reagal or Hi – Perf. The 375 was used on chevys also and will be marked on the bottom of the tail shaft THM-375
dad had a 375 t in his chevelle years ago..you think its a 350t until u pic it up seems as heavy as a 400t
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
