Old 04-09-2004, 07:32 PM   #1
desertchevy
366 Big Block
Is the 366 CI big block chevy worth haveing? This is a tall deck motor comoing out of a 71 C-60. I looked up the numbers and they are the same for the 366 and the 427 tall decks just the bore is different. The only reason that I think that it is a 366 is the build sheet on the glove box door says that it is the motor that was in it originally. They are going to auction it off at work and has gone through 2 auctions already with no bids. I bet that I could get it for under a $100.00. Let me know if any of you have any info on these tall deck motors. Thanks
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 04-09-2004, 07:40 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I don't know much about these motors, but I believe they were built with a small bore and designed to be more of a torque motor than HP.I think the C-60 would be a cool rod hauler or dump truck but doubt the motor is going to be much in the performance dept.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2004, 08:17 PM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Can you say 540 ..... I would have the whole thing if i could for a 100 bill
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 04-09-2004, 10:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
For a c-60, the engine is OK, but you would be way ahead if you found a tall deck 427. The 366 is a farm/ranch motor IMO...Seen WAY too many fall apart with normal use.
Old 04-09-2004, 11:56 PM   #5
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Just like longhorn said it is a farm engine. They were mostly used in dump trucks. I"ve heard nothing but negativity coming from people who've had them.
WRMZ71 is offline   Reply With Quote
Old 04-10-2004, 12:00 AM   #6
desertchevy
Could'nt you just bore it out to 4.250 and have the 427? The stoke and internals are the same. I just don't know if it is worth the time since the heads and intake are specific to these engines.I have not seen any performance parts for these either, not saying that there are'nt any. Just a curious thought if it was worth the time or the money. I already have a 402 and 2 454 blocks in the garage. I could not find any factory torque specs but I did find that they made 200 hp at the flywheel which would make it hard for it to get out of its own way.
2001 Chevy Impala
2006 Corvette
2009 Fusion
Old 04-10-2004, 12:39 AM   #7
72bigblock4wd
I have a friend with a 366 in a 2 1/2 ton truck that went 325K miles before needing a rebuild. I agree that they aren't much in the performance deparment, but with the steel crank and forged rods they are bulletproof motors. I believe the 366's have the same bore as a 307 SBC, but I don't know if the pistons are interchangeable. They will probably have really small ports and valves in the heads. I would tend to say that for $100 it's worth buying, I think that the steel crank can even be used with a standard BBC to make a 427!
72bigblock4wd is offline   Reply With Quote
Old 04-10-2004, 01:21 AM   #8
1969 GMC
1969 GMC's Avatar
there are a number of board members running tall deck engines...i can think of one running a 366 and two running 427's...but of course i can't remember their names...so ttt for you.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-10-2004, 04:47 AM   #9
jku72
The tall deck engines can be made into big time powerhouses, and are prefered by those wanting more than 500 cubic inch motors. The pistons are 4 ring jobs that are specific to that engine, no interchange. The block and cylinder walls are thicker on the tall decks, and can be bored a LOT. It would be no problem to bore it to a 427. In fact, if you want to go with a long rod motor, you can stuff a 6.8 rod into these engines, with a stock crank, or if you have even more coin, can stroke it with a new crank. 600 cubic inches is possible with a tall deck.
In order to get performance out of one of these, it takes more money than I care to spend. Big bucks. In my opinion, unless you are building a super gorilla engine, it would be cheaper and easier to find a low deck engine.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 04-10-2004, 10:58 PM   #10
desertchevy
Thanks for the input. I could probably buy another truck for the pricr of a proformance rebuild. thanks
2001 Chevy Impala
2006 Corvette
2009 Fusion
Old 04-12-2004, 12:25 AM   #11
Longhorn Man
That is acurate, a 502/502 horse, with a 4l80E and everything needed would be cheaper than a mild perfomance rebuild on a tall deck.
