04-09-2004, 11:44 PM | #1 |
Hidden Hitch anyone??
Bought a Hidden Hitch for my '68 SWB (the one goes behind the license plate) and for the life of me, I can't figure how it mounts. The directions say it mounts below the frame, but that doesn't look right and it's too low. Asked the vendor and he says it goes between the frame rails. I can't get it to go there without some major frame mods (not supposed to be any mods-just drill and bolt). Has anyone installed one of these? I need advise from someone who knows from experience.
Stepsides look like real trucks! Smitty |
04-09-2004, 11:53 PM | #2 | |
Re: Hidden Hitch anyone??
Just sitting here contemplating contemplation. |
04-09-2004, 11:54 PM | #3 |
I have one for mine that I didn't get around to installing yet since I don't know if I am getting another truck to use in stead of this one.
When you say it needs frame modification to mount it, is it too long?? I know my hitch came a 3 pieces that bolt together. 2 end pieces and the center section. the end pieces should have the bolt part ( with holes) towards the bottom of the hitch and you bolt it under the frame. Not sure if it is made the same as mine or not.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
04-10-2004, 01:12 AM | #4 |
Keepin an eye out
I got mine from ECE. Clamped it to the bottom of the frame, drilled a couple new holes, used a coulple existing holes, cake walk.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
04-10-2004, 03:06 AM | #5 |
I hope it didn't come from AIM. I have seen their version of a "hidden hitch" ... the only thing hidden from view is the refund that they WON'T give ya.
04-10-2004, 12:01 PM | #6 |
I have clamped it to the frame rails as Boraxman advises but it looks out of place and too low. Come to think of it, shouldn't it be marked "Hidden Hitch" on it someplace?? This unit is one piece-not three.
Stepsides look like real trucks! Smitty Last edited by smitty62; 04-10-2004 at 01:40 PM. |
04-10-2004, 01:47 PM | #7 |
Hidden hitch, cont'd.
Further to the above, here is a pic of what I have clamped to the bottom of the frame. Sorry for small size, but it's all the forum would allow! Need help, advice!
04-10-2004, 01:56 PM | #8 |
That's correct. The bottom edge of the hitch is even w/the bottom edge of a sport bumper & the receiver (access hole in the LP box) is about .5 - .75" from the bottom edge of the license plate box.
I just went out & looked @ mine to verify this info. If you want, take a measurement from the bottom of the frame rail to the bottom of the hitch on yours & I'll compare w/mine.
04-10-2004, 02:12 PM | #9 |
Thanks Scotti--I guess that's right but it looks like-----poor engineering ( not what I really wanted to say). The vendor has now verified that it's not a "real Hidden Hitch" and that it mounts as you stated. I paid 'way too much for a jury-rigged counterfeit. And, guess where it was shipped from? You're right, our "friends" in Orange, Ca.
04-10-2004, 02:58 PM | #10 |
Smitty,
I just installed mine in Jan./Feb. of this year. From your picture, the location looks correct. I also clamped the hitch in position to the frame and drilled holes. It was a little tougher than I expected, but I was installing it in a Blazer, so I didnt have to option to pull the bed. I purchased mine from ECE. So far, I love it! Here are some pics that might help. I left them big so you can see some detail. Jason
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
04-10-2004, 02:58 PM | #11 |
Apparently ours mount the same way. I'm pretty sure I got mine from Classic Perf Parts (or possibly ECE).
I feel that mine is hidden though.... you can't tell it's there until you flip the license plate up or crawl under the truck. Mine looks just like K5hart's.........
04-10-2004, 02:58 PM | #12 |
2
04-10-2004, 02:59 PM | #13 |
3
04-10-2004, 03:00 PM | #14 |
4
04-10-2004, 03:02 PM | #15 |
This is what I started with. You can see why I love the new set up!
04-10-2004, 03:08 PM | #16 |
OK Guys! That is the kind of info I needed and it looks like it's located right. I still think the hitch was intended for a different vehicle and was "adapted" for this use--normally the tongue weight is carried by the flange setting on top of the frame rail instead of just the bolts.--a much better way of attachment. Thanks again-as usual the board came through!
BTW-K5hart, I'd sure like to know how you got the site to accept those large pics!
04-10-2004, 07:25 PM | #17 | |
here is a link to a thread explaining how to do it: http://67-72chevytrucks.com/vboard/s...ht=how+to+post HTH MG |
04-10-2004, 08:00 PM | #18 |
RUNN over AGAIN!!!
My dad had one made for his/MY Truck about 5 years ago. and i recently Added a FLIPDOWN Lisence plate holder of a Nova. and it works GREAT no pics now though. it BAD!!!!!!!!!!
67-72 TRUCKS ROCK 70 SWB shaved and a 72 front clip.and a poly tank. Peep mirrors and a BIG BLOCK 468 in the making. XNXNXNXNXNXNXNXNXNXNX ,/. EMAIL ME HERE!, Dont pm me please ,/. |
04-11-2004, 12:47 AM | #19 |
Where would be a good place to get a flip license plate holder from?? Since I already have the hitch ( just have to install it) and am mounting it behind the plate.
04-11-2004, 12:51 AM | #20 |
Keepin an eye out
ECE has them. Also I believe they are availible through GM.
04-11-2004, 12:56 AM | #21 |
I need something located in Canada, but I will ask my friend that works for a GM dealer in the parts department to see what I can get.
04-11-2004, 01:24 AM | #22 |
Before and After
I just installed a modified hitch from my 94 truck (a 3 peice hitch). I reversed the side brackets and flipped the center peice. I was able to use 1 exhisting hole, and ground off a rivet that holds a x-member I just had to drill 1 new hole in the frame. It lines up prefectly behind the plate. I was thinking of making a reciever that holds my plate. If I pull a trailer, they won't see the plate anyway.
It only took 2 hours for this even with the brainstorming with my neighbor for a beer.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA Last edited by WB72; 04-11-2004 at 01:26 AM. |
04-11-2004, 02:13 AM | #23 | |
I would think you could pick up one really cheap ... compared to a new one. |
04-11-2004, 04:41 PM | #24 |
Smitty - Glad I could help with the pics. I took a lot of the hitch and new gas tank install. Figured they could be helpful someday. MG is right on about the pics. I have them hosted on Photobucket.com.
GMC69 - I got my flip license plate bracket in a kit with the hitch from ECE. But..... it is a GM part. Here is the GM part number - 14083879. Jason
04-11-2004, 05:40 PM | #25 |
older cadillacs have the flip up license plate if youre looking in junkyards... they were originally for hiding the gas filler.
70 longbed 496/th400/Ford 9" |
