![]() Join Date: Feb 2001
Braided hoses?
Ok lets hear it................
Pros and cons................ Good or bad brands...... Was thinking about just the heater hoses and radiator. |
Mudder,
How were you planning on attaching the hose? Just with hose clamps, or the covered hose clamps? I haven't decided if I'm going to use it for the radiator and heater hoses... I've been using Earl's on my truck. Very good quality, and even better, a local dealer that's been very, very helpful.
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
Not sure what to do or what I will do..............just starting to explore this.
Not cheap, but the most beatiful radiator/heater hoses I've ever seen here.
I've used the braided covers before on these hoses but it was a major pain in the *ss to install, the covers for clamps weren't very good and they didn't exactly match the Aeroquip braided power steering and tranny lines.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc Last edited by 68LSS1; 04-10-2004 at 02:03 AM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Mudder I would also go with the cool flex hose's they are pretty killler looking ..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Have been checking out the ones Summit sells. but these look a lot nicer.
67-72 Addict!
Randy,
I used just the braided sleeves, obviously cheaper than the cool flex which are pretty sweet. I bought Russell brand off ebay for about $30. The draw back to the sleeves are they hold heat!. No doubt the other ones are super nice but for now these dress up my engine compartment nicely. This pic was taken 2 years ago but looks pretty much the same except for new carb. One other thing I will add, I had to wrap a 3" section of plastic wire loom around the heater hose that touches the nut on the backside of my alternator to prevent it from arcing. ![]()
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
