SOON TO BE A STEP SIDE
Rip It To Pieces?
im starting to repair my longbed stepside bed on my 67
after i remove it from the frame should i take it all apart working on each piece individually or do i start sanding and grinding on it as a whole there is no wood on it just steel supports any input would be great it seems to be pretty solid with only minor cancer on the rear areas
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY! 4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON |
I would unbolt everything but leave the rear cross support connected to the bed sides as it is welded. It makes a little awkward but you can brace the front with an angle. That way you can get at most everything and clean it up good.
Jim |
THANKS
THAT WAS THE WAY I WAS LEANING TOWARDS I THINK I CAN DO A MUCH BETTER JOB THAT WAY
i love summertime
definately strip it apart, its the proper way to do it..you know exactly what your working with then, and you wont miss anything
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
