Old 04-10-2004, 07:25 AM   #1
Virginia72SWB4X4
A/C Pulleys on a 72 Small Block?
I'm adding A/C. Is the crank pulley a three groove style with the outer groove larger in diameter?
Is the water pump pulley a two groove and both are the same diameter?
I've got access to a couple of donor vehicles, not all 67-72 but the pulleys look similar to me.
Opions and pics welcome!
Cheers,
Virginia72SWB4X4 is offline   Reply With Quote
Old 04-10-2004, 07:28 AM   #2
JimKshortstep4x4
Talking
Both sets of pullys are the same diameter. I can get numbers off of the pullys if you need them.
Be careful mixing pullys as you can end up with misaligned belts.
Jim
Old 04-10-2004, 07:55 AM   #3
Virginia72SWB4X4
Jim,
Thanks I am concerned about that. I don't have all the compressor mounting brackets yet so I'm doing this kinda blind right now.
If it's not to much trouble numbers would help
Gary
Old 04-10-2004, 09:11 AM   #4
pickupman
pickupman's Avatar
Gary, the water pump pulley is the same diameter with 2 groves. The crank pulley is actually 2 pulleys, one sets inside the other and both are same diameter. inner pulley is single grove and outer is 2 groove.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 04-10-2004, 02:20 PM   #5
Virginia72SWB4X4
Bill,
Thanks! I may be coming up to see you. Do have compressor brackets and maybe pulleys?
Gary
Old 04-10-2004, 05:20 PM   #6
pickupman
pickupman's Avatar
Gary, I have brackets, maybe pullies, I'll have to check.
Old 04-10-2004, 09:34 PM   #7
JimKshortstep4x4
Talking
Here are the part numbers for the crank pullys and the water pump pulley.
Water pump pulley is a double, PN 1235778
Crank pulley, inner double, PN 3744043 BA
Crank pulley, outer single, nests into inner, PN 3751232
Here is a pic, sorry about the quality, I have trouble with black parts as they don't show up well.
Jim
Old 04-11-2004, 08:04 AM   #8
Virginia72SWB4X4
Thanks Jim that helps alot. I see now the donor vehicles aren't the same.
Gary
