Old 04-10-2004, 12:56 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
short h2o pump vs. long pump
I'm gettign closer and closer to getting the new bored 60 350 running and i'm fighting the h2o pump issue.
I'm really leaning toward a long shaft one. But whats the advantage - if any.
How can i find one at the parts store (what do i ask for) b/c i've asked for the long pump and i get that deer w/ headlights in eyes comming at 75 look.
I'm putting electric fans on the rad.
and i can't find a harmonic balancer w/ grooves at autozone or ebay. (if you can help for cheap let me know)
Thanks, sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 04-10-2004, 08:11 PM   #2
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
sswj,
I had several issues with my water pump. I have a '69 307 V8, and switched from a long pump (which fit fine) to a short pump, to accommodate Alt brackets.
From what I was told was there is no performance difference between stock water pumps. There is a 1 3/8" length difference between the pumps. (based on the image below)
What I learned is that the pump you choose will change what pulleys and Alt brackets you use, but that's all.
If you want a long pump, tell the parts person you want a pump for a 74-75 small block chevy. The missing space of no fan should allow enough room for the electric fan.
Hope this helps as far as the water pump.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 04-11-2004, 12:01 AM   #3
Chevy67Tk
Chevy67Tk's Avatar
What brackets and pulleys you have now or are planning on running is what’s going to make the difference in witch pump you need to use.
To my knowledge there are no SBC balancers with groves cast in them, you will have a pulley or series of pulleys bolted to it.
Chevy67Tk is offline   Reply With Quote
Old 04-11-2004, 12:12 AM   #4
whitesswj
Embrace the Redneck
whitesswj's Avatar
what do you mean? can you get me a pic of this? thanks sswj
'01 Camaro
Old 04-11-2004, 08:47 AM   #5
Blue Beard
Blue Beard's Avatar
What pumps were used on the 292 I6....long or short...?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-11-2004, 09:01 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Small block Chevies use a bolt on pulley for the harmonic balancer. It's held on by three 3/8 fine thread bolts.
Here's a short water pump type harmonic balancer pulley...
Old 04-11-2004, 10:20 AM   #7
jorgensensc
jorgensensc's Avatar
Since we are talking about pullys now, here is my question to add on:
My truck ('72) was originally a California truck, complete with Smog pump and all. The PO took off the smog pump when he redid the engine, but left the pullys. The crank pully has 3 grooves, and this is a non A.C. truck. I am going to get Vintage A.C. here very soon, so will this 3 groove pully work fine, or is a pully setup for smog different than one set up for A.C.?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
