switching electric windows to manual
im tired of messing with my electric windows on my 79 K10. will the manual window stuff bolt right on? what exactly will i need? or does anyone have a motor that is used that i can buy?
Semper Fi seafoam green 79 K10 stepside with a 6" lift, 33" baja claws, billet interior, autometer gauges, 350/t350 |
Professional Grade
If you do decide to switch over -- I'd be interested in buying your driver's side power window switch!
I dunno anything about the swap, but keep me in mind if you do it...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
The doors are supposed to be the same So i would assume get the proper regulators and remove the wires out of your door and unplug them from the main harness. Shoulndt be too bad . Have you got electric locks too?
The doors are the same. If you are going to switch back you will need the manual regulators and parts. The 79 Pwr Window are externally grounded and have there problems. 81 and Up were changed to Internally grounded with less problems. The motors, switches, etc. are cheaper and easyier to get. but you would have to change everything, Pwr window & locks wiring harness (which is seperate from the main harness), switches, regulators, etc. I did the swap in my 79 K3500 3+3
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 04-11-2004 at 12:22 PM. |
Im Thinking of doing the same thing. Mine is an 85 and I ate that the windows move slow
2004 Silverado Crewcab (Dark Spiral Gray) |
