04-10-2004, 08:05 PM | #1 |
PROJECT 7DEUCE
What I did and found today..
Well today all I was gonna do was fix my sagging driver's blazer door.. The door pocket was cracking and I figured I would just weld it back together...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-10-2004, 08:08 PM | #2 |
PROJECT 7DEUCE
So I welded up the crack's threw on some epoxy primer and went to mount the door..
04-10-2004, 08:11 PM | #3 |
i love summertime
right on french, job well done, now you dont have to slam the doors!!
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
04-10-2004, 08:15 PM | #4 |
PROJECT 7DEUCE
I thought before I mount the door back up I would put on some better hinge's since the one's on the blazer seemed to have a lot of slop in em... Tried to remove the bolt's for the lower hinge ,but apparently the thread boss for the lower hinge was gone... The previous owner remied this by cutting a hole in the kick pannel and putting bolt's with nut's on em.. So I figured I would just weld the nut's to the body and leave em, well when I hit the metal with the disk grinder to get a good ground for the welder bondo dust flew every where... I thought WTF is bondo doing in here... Well I knew that at that point I should have left it alne but ,could not live with so I grabbed the wire wheel and found this!!!!!
04-10-2004, 08:19 PM | #5 |
PROJECT 7DEUCE
Yes all those gap's were filled up with bondo..
04-10-2004, 08:21 PM | #6 |
PROJECT 7DEUCE
Yep it look's like the dope smoking old man was at it agian.... Do the make a patch pannel for this area on the blazer's??? I want to cut out this crap and fix it right...
