Old 04-10-2004, 11:00 PM   #1
meathead95
computer illiterate
meathead95's Avatar
bb frame mounts
whats the difference between 71 and 72 bb frame mounts? anyone got a pic?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-10-2004, 11:26 PM   #2
bigskiohio
72 look like newer clamshell mounts and towers, but are different
slightly on the mounts.
bigskiohio is offline   Reply With Quote
Old 04-11-2004, 09:21 AM   #3
meathead95
computer illiterate
meathead95's Avatar
come on guys somebody has to have a pic of these parts. i found a pic of the bb 71 mounts now does anyone have a pic of the bb 72 mounts
72 2wd blazer
72 swb 4x4
Old 04-11-2004, 10:46 AM   #4
bigskiohio
look in lmc catalog it shows the difference
Old 04-11-2004, 12:12 PM   #5
jmanz69
Careful, they attack...
jmanz69's Avatar
The 72 mounts look just like the 73-87 small and big block mounts with only slight differences.
jmanz69 is offline   Reply With Quote
Old 04-11-2004, 12:33 PM   #6
Orence1
Orence1's Avatar
Found this using the search feature. I think it has what you are looking for. Good luck
http://67-72chevytrucks.com/vboard/s...g+block+towers
Orence1 is offline   Reply With Quote
Old 04-11-2004, 01:16 PM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
Pic of 72 mounts. Hope it is good enough to see.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-11-2004, 01:18 PM   #8
too much stuff
Roadtrip!
Not letting me post pics right now, will try again later...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-11-2004, 03:16 PM   #9
bigskiohio
good pics on the above link.
Old 04-11-2004, 03:49 PM   #10
bigskiohio
bb
mount pic
Old 04-11-2004, 04:46 PM   #11
meathead95
computer illiterate
meathead95's Avatar
can you tell me what year the ones i have are
72 2wd blazer
72 swb 4x4
Old 04-11-2004, 04:47 PM   #12
meathead95
computer illiterate
meathead95's Avatar
er
72 2wd blazer
72 swb 4x4
Old 04-11-2004, 06:28 PM   #13
jmanz69
jmanz69's Avatar
Yours are the 73-87 type. They will still work but you will have to drill a hole for the rear bolt on the top of the frame. Other than that, they will be the same. They will use the rubber mount for a 73-87 instead of a 72 (slightly different). I had a set of them I was going to use and then bought a frame with the 72 mounts already in it. If you're not worried about it being year-correct, then use those ones. They are worth about $35-45 to resell. The 72 mounts are more like $100, so you are saving money this way and have the same type mount.
If you want, I can sandblast and powder coat them chassis black for a very good price for you.
Old 04-11-2004, 07:43 PM   #14
Rod
Pic of BB 1972 only frame mounts...note the one rib for reinforcing compared to the 73 up two rib reinforcing and the slightly different hole pattern
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-11-2004, 10:18 PM   #15
meathead95
computer illiterate
meathead95's Avatar
wanna trade rod?
72 2wd blazer
72 swb 4x4
