Old 04-10-2004, 11:37 PM   #1
krazy_texan
krazy_texan's Avatar
sb alternator bracket?
what are you guys with small blocks using for an alternator bracket, i have a later model 350 in my truck but my truck has a homemade alternator bracket that does not hold it inline with the pulleys on the motor, i was looking at some later alternator brackets while at the parts store but the ones the had where made to mount on the other side of the truck, i am going to go to the parts yard this next week to see what i can come up with, but i want to see what else is out there and get an idea on what i want.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 04-11-2004, 08:53 AM   #2
rage'nrat638
rage'nrat638's Avatar
here it is 35.00 shipped
rage'nrat638 is offline   Reply With Quote
Old 04-11-2004, 08:56 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
GM PART NUMBERS
Alternator brackets upper arm 460754
Lower cast iron 14015539
still available new too.
Old 04-11-2004, 02:17 PM   #4
krazy_texan
that is the same one i already have and it is not working for me, i might have to fab something up.
Krazy Texan
1990 v1500 suburban
Old 04-11-2004, 02:18 PM   #5
1972C10
1972C10's Avatar
He might be needing the long water pump Brackets. Depending if he is using the pulleys off the late model motor.
1972C10 is offline   Reply With Quote
Old 04-11-2004, 02:33 PM   #6
Tx Firefighter
The long style has passenger side alternator, the short pump has driver's side mounted alternator.
Ragenrat posted the right style of brackets for our trucks. It's the short pump type and it mounts to the front of the driver's side head in the threaded holes.
If it's not lining up, you have the wrong pulleys on your engine.
Old 04-11-2004, 02:38 PM   #7
1972C10
1972C10's Avatar
I acutally prefer the Later Style brackets There alot More Available ,
So unless your going for a resto you dont nessacairly need them . If you do have the Long Water Pump And Cant Get A bracket Let Me know I have A Ton Of them You would need three brackets In all one that goes from the water pump to in front of the alternator. One that is basically a spacer that goes from alternator To the Head The long bolt , And then the top bracket wich goes from the top of the water pump to the alternator and has the slider on it. You need to have a tapped hole in the front of the intake to use the later style brackets. There were a few that went on the thermostat housing. But There not as common.
