Old 04-10-2004, 11:42 PM   #1
Warbones
Navel Inspector
Warbones's Avatar
Glove box closing
I just spent the last hour messing with this glove blox door that I had repainted trying to get it to close (latch) nicely. I know this isn't a modern glove box and it's not going to have that feel to it. I have to close the door and then push in on it to get it to latch. Are they all this way and is there some adjustments(tweaking) that I can do? The original door I don't seem to remember it shutting as rough. Maybe I'm trippin.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 04-10-2004, 11:53 PM   #2
Sweet72
Sweet72's Avatar
did you install new gloove box door bumpers? that could cause that extra resistance. You can bend (tweak) the latching tab on the top of the opening some to make it easier to latch.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-11-2004, 12:14 AM   #3
Warbones
Navel Inspector
Warbones's Avatar
That is a good point. I may try to tweek the tab tomorrow.
WANTED 1967 IMPALA
Old 04-11-2004, 01:53 AM   #4
69 Short Fleet
You might want to have a look at your hinge also, mine needed adjustment and it closes better now, Doug
69 Short Fleet is offline   Reply With Quote
Old 04-11-2004, 02:37 AM   #5
Warbones
Navel Inspector
Warbones's Avatar
How do you adjust the hinge?
WANTED 1967 IMPALA
Old 04-11-2004, 03:14 AM   #6
Blue_71
Bloo
Blue_71's Avatar
my catch at the top can be adjusted back and forth too
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
