Old 04-11-2004, 12:56 AM   #1
WB72
Before and After
WB72's Avatar
Amount of oil in rear end.
Just a quick question, how much oil (approx) will it take to fill a 12 bolt diff with 3.73:1 posi in it?
I have the rear end out and I would like to fill it from the diff cover.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 04-11-2004, 04:05 AM   #2
jku72
I think its like 2 quarts, but thats a guess, I know I fill it till it gets to the plug hole, and it seems like it takes almost 2 of the tall skinny bottles that 90 weight comes in.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 04-11-2004, 04:47 AM   #3
pritch
pritch's Avatar
Do yourself a favor and get one of those cheap thumb pumps for putting gearlube in outdrives on boats. There at wally world for 5 bucks. Much easier than squeezing those tall skinny quarts.
pritch is offline   Reply With Quote
Old 04-11-2004, 08:21 AM   #4
JimKshortstep4x4
Talking
It sounds like you have the differential out and turned with the cover up. 3 1/2 pints will fill the rear end so that when you check it installed, the lube will be at the plug line where it should be.
Jim
Old 04-12-2004, 12:19 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget the posi additive.
