Old 04-11-2004, 11:04 AM   #1
Virginia72SWB4X4
Front Fender Seal Kit?
Whats the purpose of this seal? Would you recommend installing them? Does it help with rust prevention, etc. ?
Gary
Virginia72SWB4X4 is offline   Reply With Quote
Old 04-11-2004, 11:06 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have only seen the seal's in the catalog's but am guessing that it only quiets down the meatl to metal noise????? Were our truck's even equipped with em from the factory???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-11-2004, 11:56 AM   #3
Virginia72SWB4X4
As I understand it, cheyennes and the like had them.
Not sure though. I've seen them on several junked trucks.
Gary
Old 04-11-2004, 12:08 PM   #4
Sweet72
Sweet72's Avatar
In catalogs they're listed as dust seals/shields. I've never seen them on a all orig truck though. Maybe to keep dust from entering the vent cowl drain holes???
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
