Old 04-12-2004, 07:49 AM   #1
Madbomber88
Active Member
Madbomber88's Avatar
Pilot Bushing for SM 465 Clutch
Hopefully my last question with this clutch install. Does this application (71 CST Blazer) require a pilot bushing? It came with the clutch, but there is no mention of it in any of the manuals. Only in the directions of the clutch kit itself does it say "if your vehicle requires a pilot bushing..."
Thanks again
-Tim
71 CST Blazer
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 04-12-2004, 11:57 AM   #2
skid
You'll need one. Goes in the back of the crankshaft and aligns your transmission input shaft to the crank. Your old one is probably there but should be replaced.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 04-12-2004, 12:21 PM   #3
Madbomber88
Active Member
Ok thanks for the reply. So the bushing slides over the end of the transmission output shaft? I couldn't find the old one, does that mean it still on the engine block side?
I just can't find any info on the installation for this, and chiltons and Haynes don't mention it at all
71 Blazer CST
72 K20
Capt USAF
Old 04-12-2004, 12:34 PM   #4
skid
It will be sitting in the back of your crankshaft. They are hard to get out. If you re-use the old one, re-lubricate it with some high temperature grease (not too much though).
Toys:
72 K5 Blazer
74 Vette
Old 04-12-2004, 12:39 PM   #5
Madbomber88
Active Member
Best way to get it out simply with something long and skinny to stick in there and pull it out? Is the proper installation to pit it in there with the crankshaft, or rather to pit it on the output shaft and then stick it all in together?
71 Blazer CST
72 K20
Capt USAF
Old 04-12-2004, 12:43 PM   #6
skid
I use a internal bearing puller to remove it with a slide hammer. To install, use a socket that is the same size as the bearing, and drive it in the crank with a hammer.
Toys:
72 K5 Blazer
74 Vette
Old 04-12-2004, 12:49 PM   #7
Madbomber88
Active Member
Sounds pretty involved. Is it a really bad idea to reuse the old one?
71 Blazer CST
72 K20
Capt USAF
Old 04-12-2004, 12:52 PM   #8
skid
Depends on how much it is worn. In my opinion, I would change it. It will make a big difference in shift quality and transmission operation. I posted some pics on the clutch fork, did you see them?
Toys:
72 K5 Blazer
74 Vette
Old 04-12-2004, 01:00 PM   #9
Madbomber88
Active Member
Yes, thank you very much, I went ahead and ordered a new fork from LMC so then I'll know I have the right one with the right clip.
I appreciate the pics. Just have to figure out how to get that bushing out.
71 Blazer CST
72 K20
Capt USAF
Old 04-13-2004, 01:35 AM   #10
SS55
I have had good luck removing stubborn pilot bushings by first filling the bore of the bushing with wheel bearing grease. Then using a drift punch or a 1/2" drive extension, hammer the grease towards the crankshaft which will hydraulically force the bushing out. Of course, the the drift punch needs to be just slightly smaller diameter than the bore of the bushing.
As Skid mentioned above, a small internal bearing puller is the tool for job.
You should put in the new bushing, IMO.
Darrell
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
