Old 04-12-2004, 09:46 PM   #1
low 84
low 84's Avatar
3 or 4 series open carrier stronger?
is there any strength difference between 3 or 4 series open carriers for truck 12 bolts? my locker utilizes the stock open carrier and will work with a 3 or 4 series. i have a 3 series but i can get a 4 cheap if they are stronger.
i just need to know which i'll be using before i order my r & p.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-12-2004, 10:59 PM   #2
TIMSPEED
TIMSPEED's Avatar
Re: 3 or 4 series open carrier stronger?
I actually think the Series 3 carrier's are stronger, but I could be wrong, if I am, then they're both prolly the same...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
