Old 04-13-2004, 12:01 AM   #1
chucks70
Car hauler
What is a good size trailer if you were going to buy one to pick up these trucks or a burb? Local trader has a 16 footer fairly cheap but I'm not sure it's long enough.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 04-13-2004, 12:52 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
16' will work, 18' is better. Biggest thing is actual deck width. Wide aftermarket wheels get pretty tight sometimes, as do 4x4's.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-13-2004, 01:33 AM   #3
Chevyguy111786
a 16 footer will fit a lwb truck
Chevyguy111786 is offline   Reply With Quote
Old 04-13-2004, 02:52 AM   #4
jewels.
jewels.'s Avatar
yes - i agree there --- the biggest problem is WIDTH --- not length.....
when i moved from NY to IN, i rented a trailer from a rental company (along with a moving truck).... and we managed to pop a tire because the trailer was too skinny for my truck..... it sucked.... the truck was stuck 1/2 on the trailer with a bad tire.... couldnt get it on or off the dumb thing, and the back wheels were still on the ground..... measure the width of your truck wheels - cause aftermarket tires will cause problems (and i dont even have wide ones!).....
measure once, measure twice, measure thrice, then buy
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 04-13-2004, 09:13 AM   #5
teeitup
Just like to part out trucks!!
teeitup's Avatar
Buy an 18 footer thats wider, much better than 16 and if you resale ever, its better.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 04-13-2004, 10:49 AM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The real choice is to get one (without) the side rails. most trailers are 6 1/2' x 16' with rails but a true car hauler wont have the rails just fenders, if you are hauling ricers or small cars its not a problem but pickups can get a little tight and lowered ones may not fit at all.
sneakysnake is offline   Reply With Quote
Old 04-13-2004, 11:18 AM   #7
chucks70
Thanks for the replies. Measured the width and it is barely enough to get my 4X4 with stock tires on it. I think I'll pass, I'm sure another will turn up.
Old 04-13-2004, 11:32 AM   #8
Dean
Dean's Avatar
I have to load my K20s with the turbines and 35" BFGs backwards on my trailer to clear the fenders. It will fit with the stock rims though either way.
Dean is offline   Reply With Quote
Old 04-13-2004, 12:42 PM   #9
Beefcake
I bought mine new from a guy in missouri. 16 foot, 84 deck width... with double 7500 axles, electronic brakes, ramps extra tire.... 1000 out the door....
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 04-13-2004, 12:54 PM   #10
John Fabris
TOTY 2006
John Fabris's Avatar
Another thing is to get a trailer that has dual axels for better tracking stability, and also get either electric brakes or surge brakes. With electric brakes, you will need the control that goes into the tow vehicle, cost $45-$100. Note that electric brakes only work on a tow vehicle that is set up for them. Surge brakes is like having a brake mastercylinder on the front of the trailer. When you slow down in the tow vehicle, the trailer, still moving forward, pushes in the surge brake, then in turn, slows its tires. Surge brakes work with any tow vehicle.
I have a 16' x 8' dual axel, dovetail trailer with electric brakes, and I have had no problems with towing big and small stuff!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
