Auto trans/column linkage
Need auto trans shift linkage/connector at bottom of column.
Don't have a clue what to call it. Need the part that connects to the arm at the bottom of the steering column that connects that to the rod going down to the automatic transmission linkage. Have everything else.....just the link between the two. Email if you have one. THANKS! acloco@yahoo.com |
You can get the linkage from Summit. It is Lokar. If you do not see it, go to the Lokar site and look for it, then use Lokar's part number at Summit. I used it and it works great. I think it is about $40.
1972 Blazer body...need to get a thread started for the rest of the story |
The LOKAR kit works better, is smoother and much quieter than stock linkage.
http://67-72chevytrucks.com/vboard/s...ghlight=71Chev
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
