04-13-2004, 10:52 AM | #1 |
Resident Curmudgeon
1 more wiring question - Wiper Motor
Thanks to all that helped with horn and brake lights. Here is the last wiring ? (hopefully).
My wiper motor does not turn on in either slow or fast postion. It will turn on when the knob is pressed for the washer pump. I have tried another switch and it behaves the same. Am I lloking at replacing the motor? Or what else should I test? Thanks
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-13-2004, 11:15 AM | #2 |
Good one Jeff!
The motor is good, otherwise it would not run. Since the windshield wiper switch "grounds" the motor to make it run and the washer circuit is different, I would check the switch to make sure it is grounded. As a check you can use a ground wire to go direct to the motor which would bypass the switch and wiring. Jim |
04-13-2004, 11:21 AM | #3 |
Resident Curmudgeon
Jim, your knowledge is unsurpassed. Are you sure you weren't a GM engineer in a former life? Thanks (once again), I feel humbled.
