Need some specs ASAP
Can anybody give me the following specs for a 72 Cheyenne Super?
Length Width Wheelbase Original tire size Rear gear ratio(s) 350 CID HP rating and at what RPM Any idea what the curb weight would be? Who makes the P/S pump? Thanks! |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Well a Cheyenne Super was just a body style package... had nothin to do with different width, length, or anything... unless you got a longhorn truck... which added about 6 extra inches to a longbed... but you could get the cheyenne super in a short bed, a long bed, and I also think there is a few guys on here that have stepside bed supers.... ??? You could get them as four wheel drive also... I can't help you out with the 350 specs... but the cheyenne package was the today's equilvilant to a Silverado H.D. or so... the highest luxary package.... included woodgrain trim(exterior and interior) houndstooth bench seat... or just the scroll pattern buckets but buckets were an option, most have a cargo light on the back of the cab... but it should have the upper and lower trim on the outside of the truck, and a headliner. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
OK, 2WD LWB.
Anybody got some specs?
Truck addict
hold on, let me go outside and get some measurements
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
Truck addict
wheelbase was 127 inches.
I measured the whole length and it came out to roughly 201in. As for tire size it depends on if you have a 10 series 20 etc. but in the original owners manual it gives me these #'s 8.75-16.5c or 9.50-16.5D, I am not sure what they mean maybe someone else will know. The width was 77 in at the tailgate and like 75 up front. As far as gear ratio someone else will be able to answer that. For a BB I think it was either 4.11's or 4.56's for a small block maybe 3.73's. I know the GVW if you need that. hope that helped some. Jeremy
these were taken from a 1969 dealer ordering guide
legnth 207 3/4 width 79 wheel base 127 tire size standard 8.25-15 /4pr ratios standard 3.73 hp gross 255@4600 net 195@4000 curb weight 3743 power steering pump just guessing should be a Saginaw |
