Old 04-14-2004, 12:33 AM   #1
Budweis
Geared for Collision
Budweis's Avatar
driveshafts extended/6" Susp. Lift Kits
anyone know what i might expect to pay to get a couple of driveshafts extended? i was going to go with a 6 " lift but it says on spring type only adds 4" front and 5 1/2 " back so was thinking bout the 8" as it goes a true 8" of lift front and back but i understand will need the driveshafts extended so wanting to find out cost before get into. or does anyone have a link to a 6" spring suspension lift kit that adds a true 6" front and back? no block Kits please. seems to me the easiest part is going to be installing as i spent way too many hours trying to find what i need lol. its for a 1970 c20 3/4 ton 4x4. matter of fact if anyone has good links for reasonable suspension parts for this vehicle please leave here as ive only found like 3 or 4 places that even have anything for this truck.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 04-14-2004, 03:29 AM   #2
Mudder
Mudder's Avatar
Have you tried Tuff Country?
Mudder is offline   Reply With Quote
Old 04-14-2004, 04:46 AM   #3
Budweis
Budweis's Avatar
thanks i didnt try that i tried tough country, lol every company has close to the same name got me all confused. it doesnt tell actual lift on tuff country one ill call them tomorrow and see. whats the difference between ez-ride and heavy duty ? i notice they only sell ez-ride for 6" lifts.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 04-14-2004, 04:55 AM   #4
Budweis
Budweis's Avatar
hey forgot to ask they say this kit there #16611 only comes for 52" rear springs and not for 56" ones, where does this measurement come from so i can check mine?
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 04-14-2004, 05:45 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You should have 52" rear springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-14-2004, 12:54 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
When I had my front driveshaft lengthened and balanced it was about $110.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-14-2004, 01:21 PM   #7
Mudder
Mudder's Avatar
You may not have to do both shafts. I know of a good place in Union that can do this. Usually they just rebuild them and Yukon is about right on price.
Old 04-15-2004, 04:46 AM   #8
Budweis
Budweis's Avatar
cool thats not too bad then, according to this ruff country kit i think im going to get it has transfer case drop kit included, that means i prob dont have to lengthen at all prob now right?
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 04-15-2004, 03:57 PM   #9
smokekiki
Mike
smokekiki's Avatar
Tuffs heavy duty springs have 1 extra leaf on the bottom.Takes away some of the flex.They recomend the hd for winches and big blocks.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
