Before and After
I cut 1/4 of a coil from the front of my truck, and there is aonly a tiny difference. I would like to get a total of 1 to 1.5" drop , how much coil should be removed to achieve this?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
More Cowbell....
I cut one coil off of mine before and it dropped about 3-3.5 inches. That was with a 327 s/b Chevy in it. Results may vary if you have an inline or a BIG block. I figure if you cut a total of 1/2 a coil, you should be close. Make sure you are getting the spring back in the groove correctly. You might just need to rotate it a little more to get the correct results.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
It's a catastrophic success.
![]() Join Date: Jan 2003
do a search"cutting coils" theres a lot of info, looks like you need to cut it 1 to 1 1/2 to get the drop you want.
71 DELUX
I've cut many coils, but I've never cut them in increments, always a complete coil...or TWO (yikes!). I've done this since no matter what the vehicle was, I still wanted the spring(s) to correctly set back into place.
I cut one coil from my 350 1/2 ton springs and was shocked to get 3" of drop. So, my guess would be that you may want to try cutting another 1/4 coil, so that you are ultimately cutting 1/2. This is something though that I'd not want to try, as the springs may not seat properly with only 1/2 removed. Another good idea is to have a back-up pair of springs available, just in case everything goes wrong and you just want to get ytour truck back to where it was. I believe that vans and other related year models have springs that will work and those are usually cheap at any salvage yard. Have fun! |
Before and After
I do still have a good set of springs just for that reason. I did notice that the spring didn't sit in the pocket perfectly, do you think that will be a problem? The only thing that I can think of that will happed, is that they will twist and seat themselves.
I think that cutting a total of 1 entire coil will be too much of a drop for me.
Bucket of Bolts
I've heard of heating the coils as well. I'd be afraid of weakening the metal by doing this though.
This is the project that never ends, yes it goes on and on my friend.... |
71 DELUX
heating
Yes, I've heard of this too. The result may achieve the look you want, but the ride quality once they've been heated and cooled is supposed to me very BAD. That's only what I've been told, not from experience.
running on heated coil springs to lower a truck or car is a very bad idea unless you like a very harsh ride
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
