Old 01-23-2009, 11:44 AM   #1
au03z71
au03z71's Avatar
4 valve system
Anybody ever seen a 4 valve system utilized? Basically just a common fill and dump for the front and a common fill and dump for the rear? I'm not really interested in being a switch maniac. I just want a good ride and a mean stance with the ability to alter ride height.
au03z71 is offline   Reply With Quote
Old 01-23-2009, 11:47 AM   #2
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Re: 4 valve system
yeah i have seen them around town and what not here is a link with a lill bit about valves and being able to run 4 wheel indepentand and 4 valves http://67-72chevytrucks.com/vboard/s...83#post2789983
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 01-23-2009, 02:31 PM   #3
XXL
Señor Member
XXL's Avatar
Re: 4 valve system
The vast majority of people I know who went this route later went to 8 valves (or 6). The 4-valve setup has an inherent problem in that it allows air to be transferred from side to side. As a result, you end up with a lean problem when cornering because the air on the 'heavy' side transfers to the other side, thus causing more lean... rinse and repeat. The 8-valve setup isolates the sides from one another, which eliminates this problem.
XXL is offline   Reply With Quote
Old 01-23-2009, 05:53 PM   #4
au03z71
au03z71's Avatar
Re: 4 valve system
Wouldn't check valves cure this problem?
Old 01-23-2009, 06:03 PM   #5
Shane
Shane's Avatar
Re: 4 valve system
yes, but they are pretty close to the same price as a solenoid valve ... sooooo
Shane is offline   Reply With Quote
Old 01-23-2009, 06:42 PM   #6
XXL
Señor Member
XXL's Avatar
Re: 4 valve system
and without the control.
Old 01-23-2009, 06:50 PM   #7
joe231
joe231's Avatar
Re: 4 valve system
check valves at ace hardware are around 10 bones a piece..........
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-24-2009, 01:00 AM   #8
Shane
Shane's Avatar
Re: 4 valve system
I wouldn't advise putting the kinds of pressures seen in a bag when it is being compressed by a 3,500 lb truck on a $10 check valve ... but that's just me.
Old 01-24-2009, 01:18 AM   #9
joe231
joe231's Avatar
Re: 4 valve system
if they are rated for 200-250 psi working pressure, burst strength is typically at least 3 times that. The factor of safety, i believe is somewhere between 3 and 5....but I can't find the page right now to get the specs....
but i agree, it is not much in the way of savings, and the loss of function is probably not worth it......
CHEVY ONLY
Old 01-24-2009, 01:58 AM   #10
Shane
Shane's Avatar
Re: 4 valve system
3X safety factor on all 316 Stainless Steel fittings by Parker Hannifin ... can't say for import variety from Ace Hardware ...
Old 01-24-2009, 08:26 PM   #11
mycool72
mycool72's Avatar
Re: 4 valve system
6 valves or nothing, the weight transfer is def too much to put on a check valve...were talking about your life here!
mycool72 is offline   Reply With Quote
Old 01-25-2009, 02:54 PM   #12
redsled04
redsled04's Avatar
Re: 4 valve system
I ran 4 valves on my 88 for years and drove it daily. It It had hardly any air transfer in corners.But I still have my front sway bar and stiff slam ES-72s.
You could try it and if you dont like the way it drives. Just add more.Youre not going to crash cause youre truck leans in corners.
redsled04 is offline   Reply With Quote
Old 01-25-2009, 03:08 PM   #13
XXL
Señor Member
XXL's Avatar
Re: 4 valve system
So if I pull out 4 of my 8 valves, I'll no longer be able to crash?
With 4 valves, the lean will likely be significantly more than even a stock vehicle with stock suspension. Rubbing/cutting tires is not a good thing. Increasing the body roll characteristics beyond what the factory thought was safe is not a good thing.
Old 01-25-2009, 04:38 PM   #14
redsled04
redsled04's Avatar
Re: 4 valve system
I didnt mean you wont crash. But the lean wont be significant enough to be the cause if you know how to drive.Most of these old trucks get driven with old wore out stock suspension and lean way more than a rebuilt and bagged with four valve suspension ever will.
I just know from my truck. Mine drove great but not everyones will.
Old 01-25-2009, 05:46 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 4 valve system
OK,... say you do install check valves in-line to the bags. You hit the fill button. Air goes to the bags. Air will not transfer because of the check valve. Now,... how do you let the air out? The check valve keeps the air from transfering back out of the bag.
4 fills.
4 dumps.
Why not make your truck enjoyable to drive.
I'd leave it static before I'd run 4 valves.
Keith
Convert to disc brakes.
Old 01-25-2009, 06:34 PM   #16
redsled04
redsled04's Avatar
Re: 4 valve system
I never said I had check valves.Just 2 valves for the rear and two valves for the front.
I enjoyed it for about 50,000 miles this way.Most the time about an inch off the ground.
Old 01-25-2009, 06:40 PM   #17
lolife99
lolife99's Avatar
Re: 4 valve system
Redsled04,... I wasn't neccessarily talking to you. Sorry.
Just everyone that says to just install check valves. These check valves just flow "one way".
Keith
Old 01-25-2009, 06:43 PM   #18
redsled04
redsled04's Avatar
Re: 4 valve system
Its all good.The check valves definatly wont work the way you described.
Old 01-25-2009, 07:26 PM   #19
Shane
Shane's Avatar
Re: 4 valve system
redsled ... slow down and take a breath ... not every response is directed towards you. relax.
