01-01-2010, 06:22 PM | #1 |
3.07 gears????
i got a 12 bolt given to me today out of a truck i count the ring and pinion and got 43-14 its also stamped 43-14 if im correct this is 3.07 ??? i thought these trucks had 3.08?
01-01-2010, 07:27 PM | #3 |
Re: 3.07 gears????
my question is why is there no 3.07 gear set but a 3.08 ? why was it called a 3.08 set instead of 3.07? if it works out to be 3.07
01-01-2010, 07:58 PM | #4 |
Re: 3.07 gears????
hmm thats odd. i know they count out to almost exactly 3.07 not sure why the factory called em 3.08. the math dont work. you have stock gears
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-01-2010, 07:59 PM | #5 |
In the Forgotten far North.
Re: 3.07 gears????
My old '74 heavy 1/2ton had 3:07 gears in a 12 bolt rear end. Still got the axle out back buried under a tarp/snow&ice.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-01-2010, 08:25 PM | #7 |
like a rock
Re: 3.07 gears????
i think the 3.07 in 12 bolts and 3.08s in 10 bolts is a good guess!
01-01-2010, 08:33 PM | #9 |
Badass
Re: 3.07 gears????
found it out
12 and 10 bolts have diffrent set ups like 4.11 and 4.10 http://www.chevellestuff.com/1969/rear_axle.htm
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
01-01-2010, 09:14 PM | #10 |
Happy to be here
Re: 3.07 gears????
Not correct though. My 77 Cheyenne has a 12 bolt with 3.08 gears from the factory.
01-01-2010, 09:17 PM | #11 |
Re: 3.07 gears????
the tooth count will still be 43/14 which mathematically is 3.07 regardless what the sticker says
01-01-2010, 09:22 PM | #12 | |
Re: 3.07 gears????
I was always under the impression that it was 3.07 = Truck, and 3.08 = Car
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-02-2010, 11:26 AM | #13 | |
Re: 3.07 gears????
ALSO is there a differance between the 2WD-4WD rear ends ive read the axles where interchanged ????? |
01-05-2010, 09:25 AM | #14 |
Still plays with trucks
Re: 3.07 gears????
They had both in the car 12-bolt so they probably did the same thing in the truck. A 3.07 gear is on a 2-series carrier and the 3.08 is on a 3-series carrier in the car 12-bolt so probably the same in the truck version.
Don't ask me why they did that but they did.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-01-2010, 08:34 PM | #15 |
At the body shop.
Re: 3.07 gears????
^^^ great story anyways
" That didnt make it any newer " " Dont antique the equipment " |
01-01-2010, 10:47 PM | #17 |
6.0 powered square
Re: 3.07 gears????
there was 3.08, 3.42, 3.73,4.11
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=150
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 01-01-2010 at 10:58 PM. |
01-01-2010, 11:08 PM | #18 |
Re: 3.07 gears????
Maybe it's just a matter of what rolls off the tongue better ?
Maybe the small number differences was used to help differentiate between car and truck, or 10 and 12 bolt gears, but the system was later dropped ? For 70's trucks I've seen 3.07, 3.40, and 4.10 printed in a sales brochure. My glove box sticker says 3.40.
1977 GMC Sierra Grande |
01-02-2010, 12:37 AM | #19 |
Re: 3.07 gears????
my 12 bolt has a factory 3.07. wish it were 3.42
01-02-2010, 04:44 PM | #20 |
Re: 3.07 gears????
This made me curious since my K10 has 3.08 gears in it. Looking at the aftermarket parts available, 3.08 is what you will find in the rear 10/12 bolt (40/13 tooth count) and the dana 44 front will have the 3.07 (43/14). The true difference in ratio is only 0.0055. If folks are counting 43/14 in their rear end I'd say they have 3.07 gears from the factory, but only 3.08 are available from the aftermarket now? (summit and randy's R&P)
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
01-04-2010, 08:56 PM | #21 |
Re: 3.07 gears????
I picked up a 12 bolt from a '77 truck to go in my '87 and the axle code shows it has 3.07s
'87 SWB GMC LY6/6L90E '70 JEEP CJ5... My new toy '06 Hyundai Accent... DD Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1# |
01-05-2010, 08:50 AM | #22 |
Re: 3.07 gears????
does anyone know what i need to change my gears to either 3.73 or 4.10 they are 3.07 at the moment do i just need the ring and pinion set or a carrier too? its open and im leavng it that way !!! i know there other need parts to buy ?
01-05-2010, 09:28 AM | #23 |
Re: 3.07 gears????
If is is a 2-series carrier like I think it is then you will need a different carrier too. If they break it down like the car 12-bolt carriers you will need a 3-series for 3.73's and a 4-series for 4.10's unless you run special thick gears on a 3-series carrier then you can get 4.10's on the 3-series. Can't get 3.73's on a 4-series carrier.
01-05-2010, 10:39 AM | #24 | |
Re: 3.07 gears????
01-05-2010, 01:49 PM | #25 |
Re: 3.07 gears????
It sounds like the truck 12-bolt did not have a 2-series carrier like the car 12-bolt so you just need to find out where the gear ratio break point is for the carrier you have. A gear listing catalog would tell you.
