Old 01-01-2010, 06:22 PM   #1
78-5.3
78-5.3's Avatar
3.07 gears????
i got a 12 bolt given to me today out of a truck i count the ring and pinion and got 43-14 its also stamped 43-14 if im correct this is 3.07 ??? i thought these trucks had 3.08?
78-5.3 is offline   Reply With Quote
Old 01-01-2010, 07:10 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: 3.07 gears????
round it up?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-01-2010, 07:27 PM   #3
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
my question is why is there no 3.07 gear set but a 3.08 ? why was it called a 3.08 set instead of 3.07? if it works out to be 3.07
Old 01-01-2010, 07:58 PM   #4
cableguy0
Re: 3.07 gears????
hmm thats odd. i know they count out to almost exactly 3.07 not sure why the factory called em 3.08. the math dont work. you have stock gears
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-01-2010, 07:59 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 3.07 gears????
My old '74 heavy 1/2ton had 3:07 gears in a 12 bolt rear end. Still got the axle out back buried under a tarp/snow&ice.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-01-2010, 08:21 PM   #6
3r!c84
Badass
3r!c84's Avatar
Re: 3.07 gears????
maby 3.08 where only in 10bolt rearends,and 3.07 in 12bolts
-00 Saturn 5spd
1/4:13:90
Old 01-01-2010, 08:25 PM   #7
vern350
like a rock
vern350's Avatar
Re: 3.07 gears????
i think the 3.07 in 12 bolts and 3.08s in 10 bolts is a good guess!
vern350 is offline   Reply With Quote
Old 01-01-2010, 08:26 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: 3.07 gears????
did i win? did i guess right
-00 Saturn 5spd
1/4:13:90
Old 01-01-2010, 08:33 PM   #9
3r!c84
Badass
3r!c84's Avatar
Re: 3.07 gears????
found it out
12 and 10 bolts have diffrent set ups like 4.11 and 4.10
http://www.chevellestuff.com/1969/rear_axle.htm
-00 Saturn 5spd
1/4:13:90
Old 01-01-2010, 08:34 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 3.07 gears????
^^^ great story anyways
Old 01-01-2010, 09:14 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 3.07 gears????
Not correct though. My 77 Cheyenne has a 12 bolt with 3.08 gears from the factory.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-01-2010, 09:17 PM   #12
cableguy0
Re: 3.07 gears????
the tooth count will still be 43/14 which mathematically is 3.07 regardless what the sticker says
Old 01-01-2010, 09:22 PM   #13
LONGHAIR
Re: 3.07 gears????
I was always under the impression that it was 3.07 = Truck, and 3.08 = Car
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-01-2010, 09:26 PM   #14
3r!c84
Badass
3r!c84's Avatar
Re: 3.07 gears????
-00 Saturn 5spd
1/4:13:90
Old 01-01-2010, 10:47 PM   #15
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 3.07 gears????
there was 3.08, 3.42, 3.73,4.11
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=150
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-01-2010, 11:08 PM   #16
Pyrotechnic
Pyrotechnic's Avatar
Re: 3.07 gears????
Maybe it's just a matter of what rolls off the tongue better ?
Maybe the small number differences was used to help differentiate between car and truck, or 10 and 12 bolt gears, but the system was later dropped ?
For 70's trucks I've seen 3.07, 3.40, and 4.10 printed in a sales brochure. My glove box sticker says 3.40.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-02-2010, 12:37 AM   #17
karl
karl's Avatar
Re: 3.07 gears????
my 12 bolt has a factory 3.07. wish it were 3.42
karl is offline   Reply With Quote
Old 01-02-2010, 11:26 AM   #18
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
that is what mine counted 43/14 i went to buy it because the guy told me it was 3.73 i counted it and it was 43/14 he gave the rear end to me!!!
ALSO is there a differance between the 2WD-4WD rear ends ive read the axles where interchanged ?????
Old 01-02-2010, 04:44 PM   #19
MTCK
MTCK's Avatar
Re: 3.07 gears????
This made me curious since my K10 has 3.08 gears in it. Looking at the aftermarket parts available, 3.08 is what you will find in the rear 10/12 bolt (40/13 tooth count) and the dana 44 front will have the 3.07 (43/14). The true difference in ratio is only 0.0055. If folks are counting 43/14 in their rear end I'd say they have 3.07 gears from the factory, but only 3.08 are available from the aftermarket now? (summit and randy's R&P)
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-04-2010, 08:56 PM   #20
lnwlfbsktbll
lnwlfbsktbll's Avatar
Re: 3.07 gears????
I picked up a 12 bolt from a '77 truck to go in my '87 and the axle code shows it has 3.07s
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 01-05-2010, 08:50 AM   #21
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
does anyone know what i need to change my gears to either 3.73 or 4.10 they are 3.07 at the moment do i just need the ring and pinion set or a carrier too? its open and im leavng it that way !!! i know there other need parts to buy ?
Old 01-05-2010, 09:25 AM   #22
68 TT
Still plays with trucks
68 TT's Avatar
Re: 3.07 gears????
They had both in the car 12-bolt so they probably did the same thing in the truck. A 3.07 gear is on a 2-series carrier and the 3.08 is on a 3-series carrier in the car 12-bolt so probably the same in the truck version.
Don't ask me why they did that but they did.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-05-2010, 09:28 AM   #23
68 TT
68 TT's Avatar
Re: 3.07 gears????
If is is a 2-series carrier like I think it is then you will need a different carrier too. If they break it down like the car 12-bolt carriers you will need a 3-series for 3.73's and a 4-series for 4.10's unless you run special thick gears on a 3-series carrier then you can get 4.10's on the 3-series. Can't get 3.73's on a 4-series carrier.
Old 01-05-2010, 09:40 AM   #24
jrsavoie
Re: 3.07 gears????
What does it cost to switch gears in a 4x4 95 Tahoe. I would like to go from a 3.73 to a 3.42 or 3.07.
I've never messed with differentials. Is this best left to an exper? Any good shops for this near Illiana?
jrsavoie is offline   Reply With Quote
Old 01-05-2010, 10:39 AM   #25
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
understand !!12 bolts are alot of hassle compared to a 9" i think i might start looking for a nine inch thats been narrowed down too around an s10 width for my future 4 bar set up i just wanna run lower gears till then!! these diesel gears are terrible
