Old 10-29-2010, 09:54 AM   #1
isaacf
what holes do i fill in on my firewall
what holes do i fill in on my firewall?
1969 chevelle 350 numbers matching
1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605
1993 subaru impreza
1969 blazer cst 8" lift
isaacf is offline   Reply With Quote
Old 10-29-2010, 10:05 AM   #2
fishingjred73
fishingjred73's Avatar
Re: what holes do i fill in on my firewall
What are your plans are you going back with stock wiring harness, standard transmission, or emergency brake?
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 10-29-2010, 10:07 AM   #3
KEL
72 GMC
KEL's Avatar
the ones you aren't going to use !!!!!
KEL is offline   Reply With Quote
Old 10-29-2010, 10:19 AM   #4
tonypaul
tonypaul's Avatar
I filled in everything except, brake booster and steering column. I did a engine/trans swap so I knew my gas petal cable was going to be in a different location. Im also rewiring the whole truck with a new harness. I mounted the fuse box up high on the drivers side kick panel and ran the wires down through the vent in the kic panel. I wanted a real clean look with very little wires showing so its takening a little longer to get it done.
tonypaul is offline   Reply With Quote
Old 10-29-2010, 10:19 AM   #5
isaacf
thank you this is really healpful!
1993 subaru impreza
Old 10-29-2010, 10:51 AM   #6
big_al_71
big_al_71's Avatar
Here is a pict of mine when it was being done. You need to know what are you going to run thru the firewall before you start which is what we did.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-29-2010, 10:18 AM   #7
isaacf
its going in a 1971 so im replacing the drivers side of the firewall to deal with the relocating of the wiring harness and the e brake it is an auto. but all factory
1993 subaru impreza
