72 GMC
Re: what holes do i fill in on my firewall
the ones you aren't going to use !!!!!
I filled in everything except, brake booster and steering column. I did a engine/trans swap so I knew my gas petal cable was going to be in a different location. Im also rewiring the whole truck with a new harness. I mounted the fuse box up high on the drivers side kick panel and ran the wires down through the vent in the kic panel. I wanted a real clean look with very little wires showing so its takening a little longer to get it done.
thank you this is really healpful!
1969 chevelle 350 numbers matching 1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605 1993 subaru impreza 1969 blazer cst 8" lift |
Here is a pict of mine when it was being done. You need to know what are you going to run thru the firewall before you start which is what we did.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
