Old 01-22-2011, 08:46 PM   #1
towersddg9
towersddg9's Avatar
12 bolt Help
Any idea's on getting the pinion shaft out, it moves some either way but not much, the shaft lock screw came out intact, what's the secret here
towersddg9 is offline   Reply With Quote
Old 01-22-2011, 09:30 PM   #2
Big Fenders
Re: 12 bolt Help
You removed the bolt that holds in the shaft. Remove the shaft. You will notice a C clip that holds in the axles. One for each axle...remove those and pull axles. Remove spider gears in the carrier assembly and take off the caps that hold the carrier bearings in place. Remove carrier and pay attention to any shims that are next to the carrier bearings...each side. Remove pinion shaft nut and yoke assembly and then you can remove the pinion shaft. This may be more than you want to do but these bearings are set to thousands in tolerances. Would be a good idea to study up on this job before you jump in.
Bob
Big Fenders is offline   Reply With Quote
Old 01-22-2011, 10:14 PM   #3
SFTorange
SFTorange's Avatar
Re: 12 bolt Help
My shaft came out fairly easily, but there are some ridges on it that took a little nudge to push through. I think you'd be safe to tap on it lightly with something to get it to push through. If you are just planning on pulling the axles, make sure not to rotate anything after you get the pin out, or the spider gears will fall out.
SFTorange is offline   Reply With Quote
Old 01-22-2011, 10:48 PM   #4
towersddg9
towersddg9's Avatar
Re: 12 bolt Help
Thanks, It will move out bout a qtr inch but seems to hit a snag either way, everything is coming out for powdercoat, going back with new stuff and posi have a old timer diff guy putting it all back in
Old 01-23-2011, 12:12 AM   #5
blackedoutharley
Re: 12 bolt Help
Brass punch and a hammer.....
blackedoutharley is offline   Reply With Quote
Old 01-23-2011, 10:57 AM   #6
66farmer
66farmer's Avatar
Re: 12 bolt Help
You can't drive the pin straight back it will hit you will need to rotate the carrier so that the pin comes out of the rear of the carrier at 2:00 o'clock location.
Good luck
66farmer is offline   Reply With Quote
Old 01-23-2011, 09:11 PM   #7
bama63
bama63's Avatar
Re: 12 bolt Help
BFH...and a punch, the pin is tool steel so you are not going to hurt it
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 01-23-2011, 10:20 PM   #8
towersddg9
towersddg9's Avatar
Re: 12 bolt Help
Well as you can see I used the BFH and got some movement, notice the broken brass punch (two) I'm at and angle so as not to bottom out and have got this far either way, maybe I need to move up to the BAFH, anyway I did get my upper control arms back together, and thanks for all the info.
Old 01-24-2011, 09:43 PM   #9
Big Fenders
Re: 12 bolt Help
Your origional question was how to remove the pinon shaft...from your picture your not even close to removing the pinon shaft. Looks like your axles are still in also. Romove c clips from the axles and pull them and then remove carrier to access pinon shaft.
Bob
Old 01-24-2011, 10:55 PM   #10
towersddg9
towersddg9's Avatar
Re: 12 bolt Help
[QUOTE=Big Fenders;4435898]Your origional question was how to remove the pinon shaft...from your picture your not even close to removing the pinon shaft. Looks like your axles are still in also. Romove c clips from the axles and pull them and then remove carrier to access pinon shaft.
Bob[/QUOT
Thanks but the shop manual sec 4-22 says different Ive looked at pulling those clips out but limited access with that shaft in the way, Im going at it with the BAH and steel punch, got a nasty one off a tool truck
Old 01-25-2011, 01:48 AM   #11
SCOTI
SCOTI's Avatar
Re: 12 bolt Help
Bob
I believe he's referring to the pin that keeps the axles in place.... THAT pinion shaft. That must be removed before the c-clips can come out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-29-2011, 04:19 PM   #12
towersddg9
towersddg9's Avatar
Re: 12 bolt Help
Thanks SCOTI and BAMA63 the steel punch did the trick,with help from the BFH that shaft had metal build up on it and was hanging up, it was bad enough I had to get the cutting wheel on it twice
Old 01-23-2011, 10:26 PM   #13
bama63
bama63's Avatar
Re: 12 bolt Help
you can use a steel punch, you wont harm the tool steel pin.
Old 01-23-2011, 11:05 PM   #14
SCOTI
SCOTI's Avatar
Re: 12 bolt Help
Keep doing what you're doing.
I hit them from the front a little @ a time. After each hit I rotate the differential making sure it clears (you don't want to knock it so far that you can't rotate the differential). Once it's as far as it can be pushed in w/o interfereing while rotating, rotate the differential 180° & use some channel locks or vice grips to pull it toward you the rest of the way through.
Try, try, try, to not damage the outside edges of the pin if you plan to re-use it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
