#1 | |
Re: 12 bolt Help
![]() Join Date: Dec 2010
Re: 12 bolt Help
Thanks SCOTI and BAMA63 the steel punch did the trick,with help from the BFH that shaft had metal build up on it and was hanging up, it was bad enough I had to get the cutting wheel on it twice
