DBW installation
Okay guys finally made it home to work on my truck . I am working on the dbw pedal and trying to fab it up for my truck. Does this look like it will work location wise?
I think it looks like it is almost in the stock location but oem pedal has been out for sometime now. |
![]() Join Date: Jul 2012
Re: DBW installation
How does it feel when you sit in the seat and depress it?
That looks just like the same as my pedal even the bracket. Now all you have to do is bend that lower tab to the same angle as the floor. Mine was from 06 Tahoe.
Mind came from a 06 gmc 2500 hd.. I tack welded it in place for now.. was looking a the tabs on how to use them. DI'd you like the way it turned out look wise?
![]() Just wanted to show you how close they resemble. I made spacers for the 2 tabs and used bolts. Looks good. |
Ha ha that photo was funny don't know what's going on with my photo bucket account.
![]() Used that big hole on the right to run wires out to my DBW module. If you still have the factory grommet on that wire, almost fits that hole perfect that's if you're mounting the module in the engine compartment. |
Pretty sure I don't have a cat under my dash
Haha.. yeah that looks pretty good. You have yours to the right a little more then I do. So I will need to verify that mind doesn't need to go over a little more. Think I might mount the tac under the dash |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
That's is nice. I seen a couple other people have been using then on this fourm.
If I decided to change the way I am going I might buy one off you. Thanks for the link to it. |
#12 | |
Will your bracket work with our pedal see post 7.
You will have to redrill the pedal mount holes, but it should work.
#15 |
I've been looking. I think it might set to far back. Right now mine is flush with the break pedal with the oem bracket. You're bracket 90° back to the firewall right
#16 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=631165
