Old 01-23-2016, 09:37 PM   #1
fast70swb
DBW installation
Okay guys finally made it home to work on my truck . I am working on the dbw pedal and trying to fab it up for my truck. Does this look like it will work location wise?
I think it looks like it is almost in the stock location but oem pedal has been out for sometime now.
fast70swb is offline   Reply With Quote
Old 01-23-2016, 11:14 PM   #2
Advanced Design
Advanced Design's Avatar
Re: DBW installation
How does it feel when you sit in the seat and depress it?
Advanced Design is offline   Reply With Quote
Old 01-24-2016, 01:36 AM   #3
Daaaanz67
That looks just like the same as my pedal even the bracket. Now all you have to do is bend that lower tab to the same angle as the floor. Mine was from 06 Tahoe.
Daaaanz67 is offline   Reply With Quote
Old 01-24-2016, 03:29 PM   #4
fast70swb
Mind came from a 06 gmc 2500 hd.. I tack welded it in place for now.. was looking a the tabs on how to use them. DI'd you like the way it turned out look wise?
Old 01-25-2016, 09:50 PM   #5
Daaaanz67
Just wanted to show you how close they resemble. I made spacers for the 2 tabs and used bolts. Looks good.
Old 01-25-2016, 09:53 PM   #6
Daaaanz67
Ha ha that photo was funny don't know what's going on with my photo bucket account.
Old 01-25-2016, 10:01 PM   #7
Daaaanz67
Old 01-25-2016, 10:10 PM   #8
Daaaanz67
Used that big hole on the right to run wires out to my DBW module. If you still have the factory grommet on that wire, almost fits that hole perfect that's if you're mounting the module in the engine compartment.
Old 01-26-2016, 07:01 AM   #9
fast70swb
Pretty sure I don't have a cat under my dash
Haha.. yeah that looks pretty good. You have yours to the right a little more then I do. So I will need to verify that mind doesn't need to go over a little more. Think I might mount the tac under the dash
Old 01-26-2016, 09:36 AM   #10
Hart_Rod
Hart_Rod's Avatar
Check this out:
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Hart_Rod is offline   Reply With Quote
Old 01-26-2016, 10:39 AM   #11
fast70swb
That's is nice. I seen a couple other people have been using then on this fourm.
If I decided to change the way I am going I might buy one off you. Thanks for the link to it.
Old 01-26-2016, 12:05 PM   #12
Hart_Rod
Hart_Rod's Avatar
I've sold about a 100 of them and have had no complaints, . Let me know.
Old 01-28-2016, 11:47 PM   #13
Daaaanz67
Will your bracket work with our pedal see post 7.
Old 01-28-2016, 11:56 PM   #14
Hart_Rod
Hart_Rod's Avatar
You will have to redrill the pedal mount holes, but it should work.
Old 01-29-2016, 12:41 AM   #15
fast70swb
I've been looking. I think it might set to far back. Right now mine is flush with the break pedal with the oem bracket. You're bracket 90° back to the firewall right
Old 01-29-2016, 08:55 AM   #16
Hart_Rod
Hart_Rod's Avatar
All the gas pedals in my newer cars sit about 1" forward of the brake pedal. With that being said, I also make this bracket which might work better for you:
http://67-72chevytrucks.com/vboard/s...d.php?t=631165
