CPP Rear Shock Crossmember thoughts?
I am putting together some parts to do a 3.5/5 static drop and was looking at options to change the shock location / angle. For $130 the CPP 6372RTSC doesn't look too bad. Anyone have experience using this part?
https://www.summitracing.com/parts/c...ckup/year/1970 |
![]() Join Date: Feb 2016
Re: CPP Rear Shock Crossmember thoughts?
First off I have no experience with that part. So this is merely my opinion.
According to the question on Summit's site it doesn't give you any increase in shock length. If that is true I would replace the stock mounts with some easy DIY mounts and put that $130 into the shock budget. Here is a link to how I did mine. Starting on post 517. https://67-72chevytrucks.com/vboard/...698377&page=21
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Dec 1999
The CPP shock relocation kit will change the shock location/angle. Which is what you mention:
https://www.summitracing.com/parts/clp-6372srk This is what I used on stock crossmember. It appears the crossmember might be only window dressing. I can't find anything saying what it might change or improve. |
#4 | ||
Double Post Edited. Could not delete.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-05-2022 at 04:30 PM. Reason: double post |
CPP's set-up is great if you're missing the shock x-member or if it has structural issues. If there's nothing wrong w/the x-member, I would go home-made if possible or do No Limits rear shock relocation.
If you can do your own fab work, this would be a good way to go.... https://67-72chevytrucks.com/vboard/...d.php?t=451200 https://nolimit.net/store/Dropped-Sh...unts-p26244502
![]() Join Date: Jul 2000
Many years ago I used brackets similar to those below on my 69 C10. They were made by Early Classic Enterprises. Those guys were the best, but they are no longer around.
The whole idea was to mount the shocks more upright after installing 3" dropped springs. I don't recall if the shocks are shorter than stock, but I do remember the rear end bounced around less. https://www.speedwaymotors.com/1963-...it,46363.html? ![]() If needed, shorter shocks like these are available: https://www.classicparts.com/1960-72...ctinfo/74-618/ ![]()
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#8 | |
http://67-72chevytrucks.com/vboard/s...shock+brackets
#9 | |
Is the only benefit of flipping and flattening the stock brackets to increase shock travel length? I was doing some fitting and testing today after I cut and shaped the new brackets, and it looks like flipping that bracket will make that the lowest point of the rear end. |
#10 | |
On lowered T/A apps (using lowering blocks), if over 1.5" blocks are used, the U-bolt ends are usually the lowest point & are below the scrub-line
#11 | |
#13 | |
No Harm, no foul. Sometimes guys (including me) don't read every response, just the initial question.
![]() Or maybe jimijam00 was simply agreeing with your recommendation.
#15 | |
I read the responses when possible (first initial page/pages of thread) so I don't repost info already suggested. I get it though when the thread is 40 pages....
#16 |
#17 |
I installed crossmember with CPP rear coilover kit and CPP's tubular rear end kit. Zero issues with fitment. Also used CPP track bar kit that provided proper spacing for my aluminum rear end cover. I am building just a basic street truck a 5.3 and 4L60E. Boils down to your budget and what your trying to accomplish.
1989 5.0 LX Coupe 1989 Saleen #243 1969 C-10 Fleetside 1966 Mustang Coupe GT 1965 Fastback Mustang 1951 F1 Truck |
#18 |
Thanks for the replies. I haven't done anything yet, but I will either be making new shock brackets from 2in tubing, or I will modify the stock mounts.
