12-31-2024, 06:03 PM | #1 |
No "Return to Center" Steering Woes
Ok, I’m really getting frustrated trying to get my truck to return to center after a turn. I’ve done the “caster mod” documented many times on this site, moving my LCAs about 3/4” forward. Still no good. Today I finished installing new CPP UCAs that are supposed to provide 5 degrees of extra caster but still no good. The only thing that I can think of to do is put skinnier tires on the front. Right now, I’m running 275/60/15 tires all of the way around. Has anyone solved this problem while running wider tires? Here is what I’m working with:
1964 C-10, 350/TH350 1977 C-10 Spindles Stock LCA with caster mod New CPP 73-87 power steering box Suspension is stock height |
12-31-2024, 07:41 PM | #2 |
Re: No "Return to Center" Steering Woes
Do you have alignment numbers?
Are the control arms on the correct side? Is the steering box adjusted too tight?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-31-2024, 09:50 PM | #3 |
Arms are most definitely on the correct side. Steering box is new and I haven’t made any adjustments to it. Previous steering box performed exactly the same. Camber is near 0 degrees, toe in at 1/8”. Don’t want to have professionally aligned until I get this solved.
01-05-2025, 02:42 PM | #4 | |
Camber(Driver) is -0.3 degrees Camber(Pass) is -0.1 degrees(No more negative adjustment available) Caster 15 degrees each side Toe-in is 3/32" Also had truck on blocks and checked steering lock to lock and felt no interference or dragging, etc. Last edited by kberger; 01-05-2025 at 02:49 PM. |
12-31-2024, 11:32 PM | #5 |
Perhaps post pictures of your steering setup and somebody notice something interesting.
01-01-2025, 08:37 AM | #6 |
You can get some reasonable numbers by yourself with a simple inclinometer app on your phone.
I'm a shop teacher by trade. I explain wheel alignments in THIS VIDEO, and talk specifically about Caster at the 9:30 mark. See if this helps you at all.
01-01-2025, 09:30 PM | #7 |
Also, double check that your center link is installed in the correct orientation. They can be installed backwards which will cause all sorts of drivability issues
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-02-2025, 12:40 AM | #8 |
I have the same problem and the same setup. I set the alignment with angle finder, string and tape measure. Then had it aligned at a shop. She runs down the highway straight and smooth with no wandering. But it absolutely will not return to center on its own. The streering is very light - and i suspect the box is the problem with mine. While looking for a solution I found some good info about this on the Borgeson web site:
https://www.borgeson.com/steering-sy...esign-and-tech
1964 C10 Long Bed Step Side |
01-02-2025, 12:56 AM | #9 |
Pictures of the setup are a good idea.
01-05-2025, 02:44 PM | #10 |
01-02-2025, 01:50 PM | #11 |
Those tires are pretty wide in front. I'd throw on some narrower wheels/tires just to rule out that the width is the problem or is contributing.
01-02-2025, 10:07 PM | #12 |
I had a poor return to center feel, and kind of a notchy feeling in the steering...turned out to be the nearly-new AC Delco "gold" ball joints. Replaced with MOOG and the issues went away.
01-03-2025, 12:14 PM | #13 |
Attempting to attach pics. Wow that actually worked, I will add more detailed pics this weekend. Also, I'm running about 15 degrees of caster.
01-05-2025, 02:46 PM | #14 |
More pics:
