08-07-2017, 09:02 AM | #1 |
HELP PLEASE! Engine Trouble
I have a 72 C-10 350/330hp Holley 600cfm, HEI Dist, It fires but will not start!
I have checked the fuel pressure, Good! I have checked for spark on the distributer, Good! I had the carb rebuilt, Good! I tried to replace the ignition module, still does the same thing I checked the distributer cap for cracks or damage, all looks good I checked the turn signals with the key in run position, Good! I tried dumping some gas in the carb just to check, still does the same thing I pulled the plugs out and cleaned them they were black as a struck match The manifold has gas in it so its getting fuel, so I am assuming it's something to do with spark but when I checked it with a screw driver it had spark. I don't know what to do, what am I missing? any help would be much appreciated!
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR" |
08-07-2017, 09:40 AM | #2 |
Re: HELP PLEASE! Engine Trouble
If the engine is firing the module is good. Clean the plugs try it again. If you have spark at the wires then it is not a spark issue. Sounds like a flooding issue to me. If the center insulator and the electrodes on the plugs are black, it's been running too rich. Just because the carb was rebuilt does not mean there is not an issue with it. Has the engine been run at all after the carb was rebuilt?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-07-2017, 10:05 AM | #3 |
"Has the engine been run at all after the carb was rebuilt?"
No sir it hasn't, I had the carb rebuilt because it di have a bad power valve and I thought that maybe the issues but it was only part of it.
08-07-2017, 10:39 AM | #4 |
If it feels like it's popping back through the carburetor and will not start, it is very likely you have the distributor 180 degrees out. The engine has to turn over 2X for every ONE turn of the distributor.
Take the engine to the COMPRESSION stroke on cylinder #1, then pull the cap off the distributor and note the location of the rotor. It SHOULD be point directly at the #1 terminal on the distributor cap. (I make a mark on the distributor BODY to identify where the #1 plug wire lands on the body, since the cap is off when I am inserting the distributor. Also, double check the wire connections from the cap to the plugs. Make sure they are in the correct order and start in the correct place on the cap. We just got done doing this ourselves. I've done it many times, but I was teaching my son how to do it and what to check for symptoms-wise when that happens. Sure enough he had it 180 out. He found TDC on #1 on the compression stroke by: Remove spark plug #1 Insert a wet paper towel into the spark plug port Disconnect the BATT wire from the distributor (if HEI) or remove the coil wire so you don't run spark. crank over the engine with the starter JUST enough to have it blow out the paper towel. Since the engine will spin PAST TDC, you then know you must then rotate by hand for TWO FULL turns to bring it back to TDC on the compression stroke. Pull the distributor cap and see where the rotor is pointing. If it's pointing at #6, then it is 180 out. He pulled the distributor, rotated 180 and reinserted. He was SHOCKED when it immediately fired up! Good Luck!
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
08-07-2017, 11:12 AM | #5 |
If the distributor has been out, then BILT4ME is likely right and that's the most likely cause.
If the dist has NOT been out, then I'd look at your carb, something likely when amiss when it was being rebuilt. Nothing else changed since it last ran, if I understand correctly, so I'd narrow it down to what you touched.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-07-2017, 11:51 AM | #6 |
Check timing staticly. Line up rotor under #1 position on distributor cap, piston at TDC compression stroke, then look at pointer on timing tab near crankpulley. If it is way off, I would suspect a slipped timing chain. Common on higher mileage engines, but you didn't give us details on the mileage of your engine.
08-07-2017, 12:03 PM | #7 |
If you have just one wire from the starter to the distributor , it will do this ,, most run a wire from the ing terminal on the fuseblock to the distributor .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-07-2017, 03:48 PM | #8 |
Get back to basics, check everything carefully.
As was stated, Timing. As was stated, A rebuilt carb may not be feeding fuel. Do you see fuel pumping into the carb throat when pushing pedal? As was stated, check plugs to ensure they are not fouled out. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-07-2017, 08:36 PM | #9 |
Sounds exactly like my first start up. Had the same engine and carb. My distributor was 180 degrees off after checking and double checking before trying to start it. It is easy to get it off and not realize it. Hope you can get it going.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
08-07-2017, 11:28 PM | #10 |
60-66 Nut
Is the float level in the fuel bowls of the carb set correctly?
08-08-2017, 06:43 AM | #11 |
If the spark plugs got soaking wet they may never work again.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-08-2017, 07:16 AM | #12 |
Thanks everyone, I rechecked everything but the one thing that I haven't tried that I have is what 67 chevelle stated below. This is exacly what I have going to the distributer, what is the "ing" terminal? I am no electrician, so if I run a new wire to the fuseblock I can eliminate the one to the starter?
08-08-2017, 08:46 AM | #13 |
Active Member
Re. ing: He meant ignition. A straight 12vdc wire from firewall to HEI distributor. These older trucks had a resistive wire to drop the voltage down and HEI needs full 12vdc.
You've answered the question about the truck running "after" the carb rebuild, but did it ever run before the rebuild? In other words, was the carb rebuild the only thing that happened before it quit running.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
08-08-2017, 10:03 AM | #14 |
Thank you 68gmsee, Yes sir it ran fine before the rebuild, the motor has also been recently rebuilt it only has about 1000miles on it. Everything seems to point to that wire!
08-08-2017, 02:36 PM | #15 | |
Active Member
Are you are saying it ran fine for about 1000 miles then you had the carb rebuilt and right after the rebuild it stopped running. Correct? If correct above, HEI does need full 12VDC but the wire may not be your problem. I'd check it anyway (a search will show you a lot of info on it). As mentioned above, excessive flooding could be the problem. HEI placement to make sure it's not 180 out. Remove the distributor cap, place the #1 piston at top of travel and in the compression stroke (both valves closed). HEI rotor should be pointing to #1 tower on the cap and harmonic balancer should be at "0" or TDC mark.
08-08-2017, 08:54 PM | #16 |
08-08-2017, 09:10 PM | #17 | |
Active Member
08-08-2017, 09:54 PM | #18 |
I'm confused... How does gasoline soaking spark plugs "ruin" them?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
08-09-2017, 06:32 AM | #19 |
I don't quite know the how but I've seen it happen. When my 76 Seville had fuel injection problems it would drown the plugs with gas and they would not fire. One time I had a brand new set of plugs and drowned them in less than 2 minutes. I didn't want to throw them away so I put them in my good running Cutlass. The Cutlass would not start with the wet plugs. I put the old plugs back in the Cutlass, took it for a ride and got it nice and hot. Then I swapped out the plugs and put the wet ones back in the Cutlass. It barely started and spit and sputtered and misfired for a couple miles before it cleared out. I was able to save that new set of plugs but it was a hassle. If the plugs had any miles on them at all, it wouldn't be worth it to go through the hassle of swapping plugs in a hot engine.
08-10-2017, 09:33 PM | #20 |
I don't know what causes it but I have seen cars that wouldn't start after flooding even after sitting for a couple days. Change the plugs and they fire right up and run normal. I had an old mechanic friend to show me this when I was a teenager and I didn't believe either until I saw it.
08-08-2017, 03:28 PM | #21 |
Does it turn over normally? No unusual noises when cranking?
08-08-2017, 03:32 PM | #22 |
Yes sir, turns over normally
08-08-2017, 04:45 PM | #23 |
Are you checking for spark at the plug end of the wire or the distributor cap end? Need to check it at the plug end, and it should be white-hot. If it is red/orange, then you are not getting sufficient spark.
08-31-2017, 11:37 AM | #24 |
I just wanted to thank everyone for your help!!!! 67 chevelle nailed it, It was the wire that ran from the distributer to the starter. I ran a new wire from the distributor through the fire wall to the ignition terminal and that ***** fired right up . My dog thanks you too since it's his truck I'm just the driver
08-31-2017, 02:18 PM | #25 | |
