broken rear dana 60
yesterday i was takin off and i reved up the motor pretty good and dumped the clutch and didnt have good results..
Re: broken rear dana 60
Post up some pics when you find out what's destroyed.
its all about the +6 inches
where are you located out of curiosity
Rear Dana 60s have really weak axle shafts. They are about the same diameter as a Dana 44. The shafts in a corp. rear axle (HO52/72) are A LOT stronger.
Tim |
If you're lucky its just an axle, and a new one will be about $150 and a used (probably wouldn't do that, as you just broke a used one) for like $50-75. I though Dana 60's where the $h!t? I guess stock anything will break if you push it hard enough. An axle swap is the first thing I do to any build up, because they are usually 30+years old and they weren't made with the intention of surviving 3-5k rpm clutch drops!
72 chevy
![]() Join Date: Jan 2007
Yep sounds like you broke the sheer pin. Or sometimes calles rear axles
The driver side axle shaft got twisted clean off, right before the splines. I dont have pics yet, but i will soon. I havent looked into who sells new axle shafts for that axle yet, does anyone know off hand who does? I live in Southern California; 15 mins from downtown LA.
Buy good axles if you plan on doing that alot. D60's will hold alot of abuse if they have good parts or if your in situations were the wheels slip alot.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#9 | |
Location: vacaville ca, because it as far from indy as i can be
no, front d60s are the ****!! rear d60 is meh. a 468 with a manual tranny, you need a 14bff or a d70
there is a standard TON of axle suppliers if you want to beef up. look in WWW.pirate4x4.com/forum in the vendor section |
i guess you can have some good axle shafts made through off road design.. i just thought that it would just spin the tires and not be able to gain enough traction to break it, especially since its a pickup and there isnt very much weight on it. but i guess thats not the case.. im just gonna replace the shaft with a stocker and eventually swap in a 14 bolt..
Born Psycho
![]() Join Date: Feb 2001
14 bolts are a dime a dozen, dump the dana 60 quick since you're running tires bigger than stock. i run 14 bolts in both my 72s--much stronger .
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Out draggin'
I was running a 14 bolt in my old truck. Bulletproof... Held up good with a 425hp 383 stroker, built 700R4 & 4.10's/powertrax locker.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
