Old 01-30-2007, 05:09 PM   #1
69CvyPickup4x
69CvyPickup4x's Avatar
broken rear dana 60
yesterday i was takin off and i reved up the motor pretty good and dumped the clutch and didnt have good results.. i gotta a chirp out of the tires and a snap ping from the rear axle and that was that. I think i snaped an axle shaft, but not quite sure yet, ill find out later today if the rain doesnt keep up. I put it in gear, let the clutch out and the drive shaft turns and i get a thunk....thunk....thunk....thunk.. from the rear axle on the driver side. and the truck does not move absolutely anywhere.. The rear is from a 72' c20 with leaf springs has 4.10 gears and a limited slip. Im running a mild cammed 454 bored 60 over, with a sm465 tranny and 35" mud terrain tires.. I was kinda surprised i broke it.
69CvyPickup4x is offline   Reply With Quote
Old 01-30-2007, 05:27 PM   #2
kyull67
kyull67's Avatar
Re: broken rear dana 60
Post up some pics when you find out what's destroyed.
kyull67 is offline   Reply With Quote
Old 01-30-2007, 05:34 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
where are you located out of curiosity
Old 01-30-2007, 05:49 PM   #4
Blazer1970
Blazer1970's Avatar
Rear Dana 60s have really weak axle shafts. They are about the same diameter as a Dana 44. The shafts in a corp. rear axle (HO52/72) are A LOT stronger.
Blazer1970 is offline   Reply With Quote
Old 01-30-2007, 06:04 PM   #5
70rs/ss
70rs/ss's Avatar
If you're lucky its just an axle, and a new one will be about $150 and a used (probably wouldn't do that, as you just broke a used one) for like $50-75. I though Dana 60's where the $h!t? I guess stock anything will break if you push it hard enough. An axle swap is the first thing I do to any build up, because they are usually 30+years old and they weren't made with the intention of surviving 3-5k rpm clutch drops!
70rs/ss is offline   Reply With Quote
Old 01-30-2007, 06:20 PM   #6
CrashEd
72 chevy
CrashEd's Avatar
Yep sounds like you broke the sheer pin. Or sometimes calles rear axles
CrashEd is offline   Reply With Quote
Old 01-30-2007, 07:11 PM   #7
69CvyPickup4x
The driver side axle shaft got twisted clean off, right before the splines. I dont have pics yet, but i will soon. I havent looked into who sells new axle shafts for that axle yet, does anyone know off hand who does? I live in Southern California; 15 mins from downtown LA.
Old 01-30-2007, 10:19 PM   #8
shortbed70
shortbed70's Avatar
Buy good axles if you plan on doing that alot. D60's will hold alot of abuse if they have good parts or if your in situations were the wheels slip alot.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-30-2007, 11:14 PM   #9
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Originally Posted by 70rs/ss View Post
I though Dana 60's where the $h!t? !
no, front d60s are the ****!! rear d60 is meh. a 468 with a manual tranny, you need a 14bff or a d70
if the wheel would slip he wouldnt be breaking axles!
there is a standard TON of axle suppliers if you want to beef up. look in WWW.pirate4x4.com/forum in the vendor section
trkklr77 is offline   Reply With Quote
Old 01-30-2007, 11:15 PM   #10
69CvyPickup4x
i guess you can have some good axle shafts made through off road design.. i just thought that it would just spin the tires and not be able to gain enough traction to break it, especially since its a pickup and there isnt very much weight on it. but i guess thats not the case.. im just gonna replace the shaft with a stocker and eventually swap in a 14 bolt..
Old 01-31-2007, 09:55 AM   #11
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: broken rear dana 60
14 bolts are a dime a dozen, dump the dana 60 quick since you're running tires bigger than stock. i run 14 bolts in both my 72s--much stronger .
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-31-2007, 07:50 PM   #12
bagged91
Out draggin'
bagged91's Avatar
I was running a 14 bolt in my old truck. Bulletproof... Held up good with a 425hp 383 stroker, built 700R4 & 4.10's/powertrax locker.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
